Instructions and how tos here
https://support.motorola.com/uk/en/products/accessories/automotive-navigation/ihf1000
SOURCE: Need to delete paired phones from Motorola IHF1000 car kit
Hit the talk button. Say Setup Menu. Then Say Remove Phone (phone # you want to remove). Alternately, say "remove all phones", then re-pair just the ones you want.
Manual : http://www.motorola.com/Hellomoto/Master%20Lists/Product%20Manuals/Static%20Files/US-EN/User_Guide.pdf
SOURCE: Can't answer calls using IHF1000 when paired with
Press the big blue button in the middle. It will take the call but you have to wait a couple of seconds. Don't answer the call with the phone though as it will not transfer to bluetooth (it's a sort of privacy option)
SOURCE: motorola bluetooth instructions n136 pair with IPhone
Your headset may also be called a HS850 (may look different) but the instructions would be the same. Instruction manual is here:
http://www.motorola.com/mdirect/manuals/HS850_%209489A97O.pdf
SOURCE: Does IHF1000 work with the new IPhone 4? I can't
On
your phone, make sure bluetooth is turned on (settings, general).
While
your phone is in discovery mode, turn your bluetooth device on and put
it in discovery mode (usually you have to hold the power button for 7-10
seconds).
Your phone will find the device, and you will be
prompted to enter the devises PIN number (often 0-0-0-0). Your phone
should pair with the device then.
SOURCE: IHF1000 IS NOT PAIRING SUCCESSFULLY
yes most motorola blue tooth devices have a pin pairing code of 0000 andyou have to make sure your blue tooth device is in discovery mode.
