Question about Panasonic Lands Phones
Hello, Panasonic phone kx-tga750c: the phone is fully charged and on the handset. When it rings and I pick it up, the phone dies. Any suggestions?
  • Panasonic Master
  • 3,154 Answers
Could be the batteries are just kaput. Will show they are charged but have a 2 second lifespan.
Cheapest and easiest solution is to get a new battery pack and test that.
https://panasonic.ca/viewing/ALL/KX-TGA750C/OI/TGA750C_PNQX2421ZA/TGA750C_PNQX2421ZA.pdf
Looks like it uses standard NiMH batteries, even better
Posted on Nov 13, 2019
6ya staff
SOURCE:
Bird713
SOURCE: Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
Posted on Jan 16, 2008
Anonymous
  • 405 Answers
SOURCE: Panasonic KX-TGA101S base not charging.
Here are a couple things you can try.
Clean the charging contacts, this can be done two ways. The manufacture's recommend using a pencil eraser. I recomend using a q-tip and some rubbing alchol. Just rub the alchol soaked q-tip on all the metal contacts on the bases and the bottom of the handset.
Gooo luck.
Hope this helps
Posted on Mar 12, 2008
Anonymous
SOURCE: I have a Panasonic KX-TG6051CM
I had the same problem, and it seems that the battery charging circuit in the handset had locked up, constantly charging the battery until it overheated. I was able to reset the circuit in my handset by completely draining the battery. Here is the procedure:
1. Remove the handset from the charging cradle, and leave it on for a few days until the battery runs out, and the handset finally turns off. At his point, the battery will be very low, BUT NOT COMPLETELY DRAINED.
2. Next, you must manually drain the charge remaining in the battery by shorting out the two contacts on it. Shorting won't damage the battery, since it is holding very little charge at this point. An easy way to physically do this is to remove the battery, and place a piece of thin wire across the the two contacts of the HANDSET. I am referring to the contacts inside the handset that connect to the battery, NOT the contacts on the bottom outside that connect the handset to the charging cradle. Next, put the battery back in, sandwiching the wire between the battery's contacts and those inside the handset. This will hold the wire in place. DO NOT PUT THE HANDSET BACK INTO THE CHARGER, WITH THE BATTERY SHORTED OUT.
3. Wait about 30 minutes for the battery to completely die. Remove the jumper wire, and but the handset back into the charger.
4. If the battery was fully discharged , you will get a message on the handset telling you that you should let it will charge for 7 hours. If you do not get this message, then either the battery was not fully discharged, or your problem is different from mine. Try the procedure again in Step 3 for another 30 minutes to discharge the battery some more.
5. If you get the "Wait for 7 hours to charge" message on the handset, then leave it in the charging cradle for the 7 hours requested. After that, it should work fine.
Let me know how you make out.
Posted on Aug 11, 2008
Anonymous
SOURCE: adding handset to Panasonic KX-TGA542M phone. ? how to ?
I ordered a new kx-tg560m handset for my kx-tg5632 base unit, but the enclosed instructions for registering it with the base unit were wrong. Fortunately, I found the old quick setup guide in my files.
If you do not have the same base unit and handset, go to the URL:
http://www.panaxonic.com/RegisterYourHandset.
1. On the handset, press [MENU], then press [0][0]. The handset displays "Refer to manual to prepare base. Then press OK->"
2. On the base unit, press [SELECT] until the desired extension number [H1, H2, H3, or H4] is displayed on the base unit, then press and hold [CALL] until the CHARGE indicator flashes.
3. On the handset, press the [OK] softkey.
When the handset is off and sitting in the charger, the handset's extension is displayed in the upper right corner.
Posted on Nov 22, 2008
Anonymous
SOURCE: Panasonic cordless handsets all say line in use
I had the same problem. Something makes the phone's memory get "stuck."  Take the battery out of the phone for a minute and then put it back. Then unplug the phone and plug in again. You need to do this with all extensions. The problem goes away.
Posted on Jan 12, 2009
Panasonic KX-TGA711E phone/answer phone set how do i change number of rings
There are user manuals published for many of these phone models on the internet. Just do search on "Panasonic KX - TGA711E manual"
Jan 03, 2016 | Panasonic KX TGA711 1Line Cordless...
Phone says no link to base reconnect to mainbase ac addapter
The instructions worked after the additional KX-TGA402N handset was fully charged and I kept pressing the menu/ok button of the additional handset to advance from initial settings to the handset registration mode.
How do register an optional accessory handset to my existing main base...
Feb 08, 2013 | Panasonic KX-TGA402N 3 Pack KX TGA402N 3...
How can i pick up the call from my office phone when reception phone rings
Hello,Looks like you'll need to re-program your PBX unit. I would suggest looking up: 1.5.3.3 Outside (CO) Line Access 2.2.4 Operator/Manager Featuresin the Programming manual found here:
http://www.tongxun.com.cn/data/download/Feature_Guide.pdf
Hope this helps
Nov 27, 2012 | Panasonic KX-T7730 Corded Phone
Panasonic kx-tga101s -- problem regarding making conference call - this is very much helpfull. But i have weird problem, i did call 1 person, and then i asked the person to hold and i made the other call....
Some Panasonic cordless phones come with up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones.
Jan 26, 2011 | Panasonic KX-TG2740 Cordless Phone
Hi: I have a Panasonic KX-T7420 phone. When one of the incoming lines is ringing and I pick up the handset, it picks up the intercom and not the incoming line. Is there a way to get the thing to answer...
There are 2 things that would prevent you from being able to answer a ringing phone by picking up the handset. Your phone has to be ringing, and you need to set preferred line ringing on incoming calls.
The second part is easy. Press PROGRAM 99 and dial 22 STORE on your phone. Now when a call rings on your phone you can pick it up. If you can't, then your phone is not ringing.
Ringing is set in system programming.
Carl
Aug 04, 2010 | Panasonic KX-T7420 Corded Phone
My panasonic kx-tga520m cordless handset does not display caller id anymore. the second handset does display this feature. What should I do?
Because your phone was low on battery, you will not see this feature. Once you charge your phone fully, you will start receive phone calls and you will see this feature activating again.
Jan 18, 2010 | Panasonic KX-TGA520M Cordless Expansion...
I purchase the Panasonic KX-TGA560B and I am having problems.
Hello amalia,
I think what happened is just software crush .. anyway, please contact Panasonic costumer-care Click Here or visit nearest Panasonic Service Center, you can know where is that by clicking here
Thank you for using FixYa.
Apr 11, 2009 | Panasonic KX-TGA560B 5.8 GHz Cordless...
Panasonic handset, KX-TG5632 buttons won't work
After trying all possible solutions (unplugging, replugging unit; switching batteries and, my idea of smacking the handset with my hand), I bought a new phone. :-)
Feb 07, 2009 | Panasonic KX-TG5632 Phone
Mar 24, 2008 | Panasonic KX-TG6051M Cordless Phone
Panasonic KX-TG6051M 5.8 GHz -Caller ID view problem
I have a panasonic KX-TG6051CM 5.8 phone with 3 handsets. After less than a year 2 of the 3 handsets developed the same problem, almost in the same time ( a couples of hours apart). The battery indicator shows low battery and is charging continuously even though the battery is fully charged ( when i swap the battery with my 3rd handset, the battery indicator shows fully charged and works fine ). The handsets were never dropped, never used in a moisture ladden environment ( like bathroom ) and when not in use they were kept in the charger. Any help or suggestions will be much appreciated.
Mar 23, 2008 | Panasonic KX-TG6051M Cordless Phone
Lands Phones Logo
32 people viewed this question
Top Panasonic Lands Phones Experts
Ekse
martin hogg
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
