Question about Panasonic Video Cameras
How to convert movies from Panasonic NV-DS 60 to a DELL Desktop computer.
6ya staff
SOURCE:
Anonymous
SOURCE: panasonic nv- ds 65 mini dv digital
use the USB cable only for still pix. you would need a Firewire cable to be connected from your DV point in your camera to the Firewire port on your PC. Most PCs do not have Firewire readily installed. You can buy it the firewire card IE1994 card - its cheap. the IE1994 card is used for laptops and the other kind is the one you can plug into an empty card slot on your PC. You need to take off the cover of your PC and push in the Firewire Card. Put the cover back on and its plug n play. Firewire transfers at 10x the speed of USB 2.0. You will never have the problem of dropping even one frame. Its worked for me!!!
Posted on Sep 26, 2006
Anonymous
  • 7 Answers
SOURCE: How to get my PC recognize the Panasonic NV-GS15
Solution A: make sure you are using the correct cable for what you are doing (eg USB for webcam and importing photos and Firewire for transferring video footage
most desktops have firewire plug in them but laptops don't usually
to get a firewire plug in a laptop you need a PCMCIA to Firewire Cardbus (ask your local retail store for one or buy one on ebay etc.)
after that put the cardbus in your PCMCIA slot and restart
then go to Windows Movie Maker and press "capture from video device"
hope this helps!
James
Posted on Feb 21, 2008
cropp
Irwan Darmawan
  • 377 Answers
SOURCE: Re: WMM doesn't detect my panasonic nv-gs27
hi dear
just using card fire wire
and transfer it with software like: , pinacle, Ulead Video Editor, adobe premiere ...sony vegas ...cyberlink power director.and many moore
oke
cropp
Posted on Mar 21, 2008
Anonymous
SOURCE: Downloading video from Panasonic NV DS60 using windows movie maker
pliss send my draiver camera
Posted on Nov 16, 2008
normis101
  • 69 Answers
SOURCE: Instruction Manual for Panasonic VHS Movie Camera NV-M7A.
drop me an email and I will send you a photocopy if you are still looking.
Norm normis@gmail.com
Posted on Feb 14, 2010
Hi There Can Someone Please Help I Have A PANASONIC NV-DS65 DIGITAL VIDEO CAMERA (WITH MINI DV VIDEO CASSETTE)I HAVE GOOD VIDEO FOOTAGE OF MY FAMILY ON IT I NEED TO TRANSFER THIS VIDEO FOOTAGE ONTO MY...
You will require a firewire cable.
Usually a 4 pin to 6 pin cable. 4 pin to camera 6 pin to computer, assuming you PC has a fireiwre socket.
PC computer have Movie Maker as part of the OS.
Connect with the above cable and you should be good to go.
Al
Sep 29, 2013 | Panasonic NV-DS65 Mini DV Digital...
I cant taransfer my video from vz55 vhs movie camera panasonic nv vz55to pc as i do not have transfer cable pls help to find where i can buy this cable and how
To do the transfer you will require an Analouge to Digital Converter box.
You connect the camera to the A/D Converter with analogue cables (RED, WHITE AND YELLOW RCA connectors) then use a firewire cable to connect the A/D Converter to the computer.
Mar 15, 2011 | Panasonic NV-VZ55 Camcorder
How can i change my panasonic nv-gs230 mini dv
Best
1. Copy the video to your computer with WinDV. No "capturing" involved. The video resolution and PAL/NTSC format will be the same as the source.
2. Then convert to whatever format you like.
You could also use something that copy and converts the video directly from the DV, like convert to dvd with Ulead DVD Workshop.
DV is a fixed standard and comes in 50Hz and 60Hz versions.
50Hz ("PAL" 625/50) 720x576, 25fps interlace (aka 576i)
4:2:0 components, 25Mb/s Video Rate
LPCM audio 2ch 16bit 48KHz or 4ch 12bit 32kHz
60Hz ("NTSC" 525/60) 720x480, 29.97fps interlace (aka 480i)
4:1:1 components, 25Mb/s Video Rate
Meaning, You cannot change the camera. It is either a pal camera or a ntsc camera. Othewise you will have to by a firmware update from the manufacture's website.
Oct 14, 2009 | Panasonic NV-GS230 Mini DV Digital...
How to view and download the recordings
You need to purchase a device that converts analog video to digital. It looks like a little box (or cable) with video and audio inputs on one side and a USB or firewire connector on the other. There are lots of choices and prices depending on whether you want to edit the video or just view it on your computer.
By the way, don't be confused by those set top boxes that convert Digital TV signals to your old TV because of the February change in broadcast standards. That's completely a different issue.
Dec 31, 2008 | Panasonic NV-VZ18 Camcorder
Panasonic digiatal camera nv-ds65
give me your address and I will mail cd to you .
You need to use a fire wire cable and connect it to the computer. (of course you need to install the driver for the camera first).
After connecting the camera turn it on and youse any film making software to capture the movie from the camera and put it on the computer.
Sep 21, 2008 | Panasonic NV-DS65 Mini DV Digital...
USB drivers for panasonic nv-gs11 gc
I have a software for that model.... NV-GS11GC it work only on Window XP,Me,98SE
Dec 04, 2007 | Panasonic NV-GS11gc Mini DV Digital...
Panasonic nv-ds55
It sounds like the sensor is going bad. Here is the manual for the NV-DS 60, which is very similar to yours. You may need to take it to a repair shop. Good luck.
http://tda.panasonic-europe-service.com/docs/2z5a2cca0fz3z22232z656ez706466z21z1c8fc58f832b60282b1c88e0f0a7f11211283296/pgrp001/pcat008/nvds60eg/753316/IM-NVDS60-65ENG.PDF
Dec 10, 2017 | Panasonic NV-DS55B Mini DV Digital...
Video Cameras Logo
21 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
