Question about Pool & Spa
My dream maker hot tub is slowly losing heat. The light below the temp down button is continuously illuminated. Is the control panel bad or is there another issue?
Possible weak heater element or bad temp sensor
3 Suggested Answers
6ya staff
SOURCE:
Ian  Hot Tub
Ian Kime
  • 77 Answers
SOURCE: Dream Maker spa - does my dream maker spa 4 person
Depending upon the age, the Dream Maker has a digital thermostat which is easy to change but to be honest I don't think that is the cause of your problem.
Check the keypad connection on the PCB (circuit board).
t could be either the keypad or PCB at fault and withou trying one or the other you'll not be able to determine the problem. My advise would be for you to contact your local parts supplier and ask them whether or not they can supply you a keypad to try with the option to send it back for a refund if it doesn't cure the problem.
A keypad can be trial fitted to the PCB, just unplug the old one, plug the new one in and turn on the power. There's no need to install the keypad to the spa, therefore you wont damage it in anyway.
If the keypad doesn't cure the problem, change the PCB.
Regards,
Ian.
http://hottub.synthasite.com
Posted on Apr 01, 2010
TerryH
  • 111 Answers
SOURCE: My dream maker big eze hot tub the jet light on the upper control panel just keeps blinking what does that mean
Are the jets coming on when you press the button?
Try unplug the control from the board and plug it back in.
Posted on Dec 02, 2012
Dream maker spa will not heat up
bad heating element or temp sensor or recirculation pump
May 04, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
Dec 01, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
I have a flo error and i have bypassed the pressure switch due to it being bad but the motor still turens on and off just by giving the hottub power the3 temp is very cold 39 degrees can you help
could be a bad heating element go to home depot get a volt meter (dont worry its simple to use )
take the volt meter turn it to continuity shut power off put the test wire on the heating element ...Imagine this.. the heating element is like a light bulb the difference is you can see the filament ...you can see if a light bulb is bad because you can see the wires are burned in the light buld (and yes you can shake it and hear the rattle) well on hot tub heaters you cant see the filament or burnt wire so the metre will tell you if its burned out goodluck www.dollarspa.com
Jan 02, 2011 | Dream Maker Spas Dream Maker Ez Spa Hot...
Pool & Spa Logo
22 people viewed this question
Top Pool & Spa Experts
Bill Jordan
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
