Cant get to os cant freaking get to bios Cant do anything my computer is a oversized paper weight now!
Here is the screen
Intel (r) 915g/915gv/910gl pci accelerated svga bios
build number: 1235 pc 14.4 07/18/2005 09:55:21
DECOMPILATION OR DISASSEMBLY PROHIBITED
copyright (C) 2000-2003 intel corp. All rights reserved.
This is my main computer i need to fix this or esle i am screwed!
What you need to do my friend is remove the CMOS battery, then remove the power cord from the computer. Press the power button on the front of the pc, you might at this point see a temporary flash of the power LED (at this point the cmos /bios is now cleared and reloaded with the defaults.
Next, put the battery back in and then the power and boot to the bios. Just reload all settings as needed and you should be back in business!!!
Disconnect everything from the motherboard except the video card, processor, memory (1 stick), and a keyboard. Try to power up and get into the bios. If you can get into the bios now, add components until you can no longer get into the bios. The last one you added is causing a problem. If you try each stick of memory one at a time and can't get into the bios then your motherboard is bad. Possibly fixable but likely not worth the money compared to replacing it.
