Question about Tascam Audio Players & Recorders
Tascam 2488 mk2 cannot boot. Not detect hdd correct
6ya staff
SOURCE:
Anonymous
SOURCE: TASCAM 2488 won't boot up..HELP!
reseat the HDD cables, just unplug them and blow on them to remove any dust or anything on the cables and the connectors and plug them back in, but first make sure it is unplugged from the socket and once it is press the power button to let all the power out of it so you don't shock yourself , i hope I was helpful and it solves your issue
Posted on Apr 10, 2008
Anonymous
SOURCE: Tascam 2488
Repartition and format the hard drive. There are specific instructions elsewhere on the Internet. I did this about six months ago. I believe my problem came about after I stored my 2488 on top of my monitors - I believe the exposure to the magnetic fields corrupted the boot partition on the drive.
Posted on May 16, 2008
Ignatz03
  • 3 Answers
SOURCE: Boot Problem in TASCAM 2488
Turning the power off with out going through the shut-down process will sometimes trash the hard drive making it un readable. To force format of hard drive hold down the shut down, send, shift and quick routing keys at the same time then turn power on. This will format the HD. When finished the display will show "Factory initalize complete" "please power off" NOTE you will lose every thing on the HD including the demo song.
Posted on Mar 05, 2009
Dufungk
  • 41 Answers
SOURCE: When I turn on my
Secure the connection of the hard drive by pushing if firmly or
by pulling the connection, then reconnect it again.
Posted on Oct 05, 2010
Dave
SOURCE: Check H/W?
All I get is a blank green screen. I changed the hard drive and the same problem. Unhooked the connections to the mother board and the cd will open.
Posted on Apr 06, 2013
MY PC wont recognize my Tascam Portastudio device2488, i have Vista
Tascam 2488:
I use Vista and my 2488 MK1.
When you plug in the USB cable from the 2488 into your Vista PC, Vista will always say 'not recognised'.
You do not need any PC drivers for the 2488. On the Tascam 2488, go to 'Menu', then 'Disk', then 'USB Open/Close', then click 'Yes'.
On your PC the 2488 will appear as a new hard drive in the 'Computer' folder, called HDR2488.
You'll see three folders in there: WAVE, SMF and BACKUP.
Use the WAVE folder to import and export WAV files, the SMF folder to import midi files to the 2488, and the BACKUP folder is where you can import and export Backup files to and from the 2488.
Hope this helps!
May 09, 2012 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 digital portastudio
Your HD risk to be corrupted, probably need to be removed and tested on a different device, I see if I can find the schematics
regards
Mar 08, 2008 | Tascam 2488 Portastudio Multitrack...
When I turn on my Tascam 2488 it says Cannot BOOT !! Not Detect HDD correctly Please POWER OFF And Check H/W
Oct 05, 2010 | Tascam 2488 Portastudio Multitrack...
Where can I get knobs for a Tascam 2488 MKII. Trim knobs
I get a CAUTION sign when I boot up that says:
Cannot Boot! Not Detect HDD Correctly. Please POWER OFF , and Check H/W..." Can anyone assit me with resolving this problem
Thanks
Scott
Feb 11, 2010 | Tascam 2488mkii 24 Track Recording...
Cannot boot not detect hdd correctly power off and check h/w
Usual suspect is a faulty power adapter which is failing to provide enough power for the drive to spin up to speed. Try another adapter with the same ratings.
bd.
Jun 12, 2009 | Tascam 2488 Portastudio Multitrack...
HI I have the tascam 2488 mk11....have only had it a little over a year....has about 20 hrs. playing time on it as I haven't had time to use it.....Today it gave me the following message; CANNOT BOOT...
This is often due to the HD not getting enough power to spin up to proper speed when booting. Usual suspect is the power adapter. You might try picking up an after market one that matches the specs before going through the expense and trouble of shipping the unit back.
Feb 19, 2009 | Tascam 2488 Portastudio Multitrack...
Jun 19, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam 2488
Apr 10, 2008 | Tascam 2488 Portastudio Multitrack...
Apr 09, 2008 | Tascam 2488 Portastudio Multitrack...
Check H/W?
sounds like a problem with the internal disk drive, could be damaged and may need replacing... if its still within the warranty return it for repair or replacement.
Nov 29, 2007 | Tascam 2488 Portastudio Multitrack...
23 people viewed this question
Top Tascam Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Ekse
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
