Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
https://homenol.blogspot.com/
https://remotesearch.blogspot.com/
https://electronicshelponline.blogspot.com/
https://electrohelponline.blogspot.com/ ..
The following steps must be completed within 1 minute. Settings will be automatically stopped after 1 minute passes since the last operation and steps 2 through 4 will have to be repeated.
1. Use the correct remote codes for your TV.
2. Press the Code Set button on the remote using a small pointed object such as a ball point pen or small paper clip.
3.Press the TV Power button on the bottom of the remote.
4.Enter in your TV remote control code using the Numeric Keys on the remote control.
5. Once the remote control code is registered successfully the Transmit light will blink twice. If the Transmit light blinks more than twice the code registration has failed. Steps 2 through 4 will need to be repeated.
http://www.yamaha.com/yamahavgn/Documents/YEC/Other/RX-V567_Programing_remote_control_codes_for_TV_Control_Key_operations.pdf
