A
Anonymous Posted on Nov 12, 2019
I have canon 1133 it can printing but scanning gives a poor quality image What could be the problem
Gsha
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Nov 12, 2019
Gsha
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
Helped
1770
Points
13
Is the flatbed perfectly clean? If not? use some glass cleaner and newspaper or blue cleaning paper tho get every Mark off.
Though?Scanning can reduce quality anyway especially on word documents.
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Feb 09, 2009
SOURCE: Samsung Printer CLP-315W. Very poor
Get your photo printed from colour lab.Use the printer to print text and images in black.
Anonymous
  • 197 Answers
  • Posted on May 08, 2009
SOURCE: printing ghost images (shawdowing)
You'll have to align the print cartridges. You should be able to do this with the software that was installed with your printer. Hope this helps.
Anonymous
  • Posted on May 25, 2009
SOURCE: Canon MP610 Scans blurry images and photos
I had the same problem with one of these units. I had another one that worked great so I knew it should work. I called Canon and after some questions about the problem they sent me a replacement unit which works fine.
Robert Jones
  • 6 Answers
  • Posted on Jul 16, 2009
SOURCE: scanner gives poor quality scan...bulb?
I have one with the same problem. Look at the lamp. If it isn't really bright, that could be the cause. Mine is bright at one end and that is the side of the page that is good. I am not an expert so I could be wrong, but that is where to start if all else looks OK. Am looking for a cheap replacement lamp myself. But at the prices of all-in-ones, it's not worth spending much.
efs_perpends
efs_perpends
  • 1997 Answers
  • Posted on Jul 30, 2009
SOURCE: Print Quality Poor - HP Photosmart 2575 All-in-One
You can download the manual from Software & Downloads here.
Then work through this article and see here to diagnose the printing problem. Make sure the print quality is set for photos in the print preferences or properties.
You might try cleaning the cartridge contacts as described here.
Make sure you are using a good quality paper, that it is feeding correctly,
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Canon imageRUNNER 2204. How could I adjust printing quality please?
Print quality is done in the computer / printer settings. Draft is the lowest setting.
imageRUNNER 2204 - Support - Download drivers ...
https://en.canon-cna.com > support > products > imager...
Scan from Canon multi-function devices to a mobile device, upload scans to cloud storage services, attach to and send emails, and print. Other Products .
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
2answers
Canon ip4850 print quality
Whats the question?? if poor quality printing, it could be dirty ink cartridges, dirt on the print head, poor quality paper ??? try looking at the printer settings, sometimes they may be set to economy rather than top quality printing.
4answers
Canon imageRunner 1133/ 1133iF printer drivers
Download from here
https://www.canon-europe.com/support/products/imagerunner/imagerunner-1133.html?type=drivers&language=en&os=
Print quality poor for mp780. Had s800 which
There seems to be a calibration problem. Follow the calibration test from the manual.
If you are using original cartridges, go to canon for repair.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
When printed from a scanned image vertical bands appear
Well, now, jannyloubran,
I hope that I understand your question: are you saying that there are vertical bands when an image is scanned, and then printed? In other words, if you download, say, a picture from your digital camera and print it, no bands: but, if you scan a photograph, then print the scanned image, you get the bands?
Going on that assumption, I would guess one of two things is happening, and possibly both:
  1. The resolution (usually "dpi" in America) is set too low on your scanner to get a very good scan, and so the print is poor. To scan a picture, you really should set the resolution as high as your equipment will allow and your hard drive has space for (the higher the resolution, the more space the file created from the scan takes). Without getting too technical and getting into optical vs. interpolated resolutions, 1200 x 1200 is usually an adequate starting point that will give a decent image (hopefully sans bands) without taking up gigabytes of storage space per scanned photo. You need to open the scanning software that came with your printer and set the resolution higher. If you can't figure out how to do that, open the help file that came with it or go to http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13800. From here, you can search their FAQ, ask a question from their knowledge base, send tech support an email, or get a phone number for support.
  2. If your scanner is an older one (you didn't specify), then it may be either worn out (unlikely) or simply not able to support a high-enough resolution for the quality we have come to expect.
Now, if it turns out that I have been having a bad dream and none of the above applies, please repost with more information as to exactly what you have to do to replicate the problem, including what, exactly, you mean by "bands" (black and white bands, bands of fuzzy focus, bands of off colors, wide bands, narrow bands, bands all the way from top to bottom or just halfway, or what?). Also, have you changed anything else between printing from the computer and trying to print the scanned image, such as new cartridges or aligning or cleaning the printhead? I know it's a pain to spell it all out, but sometimes that's the only way we geeks can figure out how to help—and, I hope this helps!
Ken
3answers
Poor color printing quality
do you have the canon print management software installed? it's located in the maintenance tab on that software.
www.canon.com has that by model number
Poor quality printouts from my canon mp150
before printing check the quality printing in printing preferrences to change it to best or normal.
old marine
old marine
ZJ Limited
ZJ Limited
