Question about LG Microwave Ovens
The glass on door LG microwave model LMV1680DW is loose how to fix it?
6ya staff
SOURCE:
douglas smith
  • 1462 Answers
SOURCE: Microwave oven glass window on the door
do not use - there is a possibility of microwave leakage.
Posted on May 07, 2007
Anonymous
SOURCE: Cleaning inside of microwave door
THE DOOR ON MY MAYTAG MICROWAVE OVEN HAS A SCREEN OVER IT. I HAVE SOME FOOD SPATTERS THAT PENETRATED THE SCREEN AND I CAN'T CLEAN THE GLASS THAT THE SCREEN PROTECTS. HOW CAN I REMOVE THIS SCREEN TO CLEAN THE GLASS?
Posted on Nov 23, 2008
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: door glass shattered
You really should contact GE customer service. There have been reports of this glass eplosion and they may take care of it for you.
GE Customer Service is here.
If they won't help, you can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
freetek
Steve Allison
  • 5569 Answers
SOURCE: Loose glass in door
Silicone glue would be best since it has very good heat tolerance and, if the clear is used, there will be no problem with it absorbing energy but I wouldn't use any with colorant as it could have metallic pigments.
Posted on Nov 28, 2008
Anonymous
  • 284 Answers
SOURCE: Broken microwave door glass
Be very careful with microwaves. I would not work on it myself. Technicians actually have a meter to measure for leaks after they put it back together. I would be surprised if you could get parts for it anyway. You risk life and limb if you get it wrong.
Posted on Aug 15, 2009
Glass is loose inside door and moves
disassemble and replace tape or glue
Jan 25, 2016 | LG Over-the-Range Microwave
Need to know correct size of microwave door glass for LG model MG-604w mine is broken after a fall, can I still use without glass?
NO, do not use the microwave with a broken door glass, this glass is specially protected to stop any dangerous microwave leakage, it is also something you cannot replace yourself, take it to a reputable service centre so that once the glass has been repaire the oven can be tested for safety purposes.
Sep 09, 2013 | LG Over-the-Range Microwave
How to remove and replace handle on over the stove microwave oven. Model # LMV1680DW
The door handle can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle (if required) usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. Several of these sites also have helpful exploded view parts illustrations to assist you with parts identification and how disasemble/reassemble your appliance.
The door handle is a simple repair that can be done with the door in place, or with the door removed. You do not have to uninstall the oven if this is an over the range model.
NOTE: If you wish to remove the door, all you need to do on most models is open the door all the way and lift straight up at the hinges. You may have to remove the grille cover located above the door on some models to accommodate being able to lift the door.
If you have any questions, please post back and let me know. I hope this helps you.
Jul 26, 2011 | LG Over-the-Range Microwave
Glass in door is loose
you may be able to dissassemble door and reattach glass with a hot glue gun. the plastic tabs are more than likely broken.
Apr 14, 2011 | LG LMV1630 Convection/Microwave Oven
Outer glass is loose
Normally you have to separate the door panels (as shown in the attached photo).
Then you can see the screws you need to check and tighten, etc.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
May 04, 2010 | LG Over-the-Range Microwave
LG Microwave Countertop Microwave Oven LRM2060 ST. The glass on the outside of the microwave door is broken. Can you order just the glass from somewhere and can I fix it myself?
Due to the serious potential for RF leakage, these doors are normally sold as a complete unit assembled by the manufacturer. I could only find the door listed at repairclinic.com for about $80. If you wish to repair yourself, the old door comes off by opening it all the way and lifting straight up at the hinges. The door will then lift off the hinge pins. Reinstall the door new door by aligning it with the hinge pins and allow it to seat straight down. A simple repair.
If you have any questions about this repair, or require addtional assistance, please let me know. I hope this helps you.
Aug 11, 2009 | LG LRM2060 Stainless Steel 1200 Watts...
Broken glass on full sized microwave door
Unfortunately, you would have to replace the complete door assembly, you can find a replacement door assembly for this model at this link:
LG LRM1230W Replacement Part Complete Door Assembly
Jan 07, 2009 | LG LRM1230W Microwave Oven
Door outer plastic plate slide down an inch from the top
You would probably need a service manual, for which you can contact LG at 1-800-243-0000 or http://us.lgservice.com
Or locate a local servicer:
http://us.lgservice.com/gcsc/b2c/hpi/main
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Nov 19, 2007 | LG LMV1645 Microwave Oven
Goldstar Mv1526W
I would suugest that you contact LG via their site here: http://lgservice.com/
Oct 22, 2007 | Goldstar MV-1526 Microwave Oven
Microwave Ovens Logo
24 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
