SOURCE: my vizio bluray wont accept
Please connect the router directly to the computer with a network cable and switch on the router.
It will couple of minutes and your computer should have got a IP address from the router.
Go to command prompt :
1. Click on Start / Pearl / windows Orb
2. Click on Run (windows XP) / Search box (Vista / Windows 7)
3. Type Cmd and hit the enter key.
4. You will be in a black screen (command prompt)
Find the IP address of the router : Type the following
Ipconfig (and hit enter)
you will see the a number in this format - 192.168. X.X next to Default gateway.
Write down that number
Access Router page:
1. Open a browser window - Internet explorer / Mozilla
2. In the address bar type the default gateway address you noted down
3. Click on the Go button / just hit enter.
4. You should get a username & password request screen
Default ones are usually (unless any one has changed it or set differently by the manufacturer - refer the manual also)
Username: Admin or Administrator
Password: password / admin
In this screen you should be able to click on Wireless setting and there you can see your WEP key or you can change it to the one
you wanted
SOURCE: I bought my Kindle in
Hi.
What you call 'password' is the network key that has been set for your local network.
It is a problem with the capital and with special characters. The problem depends both on the network key used and on Kindle's.
First :ensure that you are using the right network key for this router. If a different computer works with this key on same router, then it is the right one.
Second: try the following. It is a solution from this site. The workaround will get rid of the capital problem with Kindle. I quote:
"Turn on kindly, bring up Wi-fi networks, tap in the network key from the label on the bottom of the router.
HERE
is the trick. When you press the Aa (large capital/small capital AA
key, to the right of the space bar, it actually does not go to uppercase
when typing in key, you have to use the shift arrow, (bottom left hand
corner of keypad).
Type in the key..., move to submit, it should connect fine".
Third: If that does not work, then the network key may include characters not supported by kindle. If possible access the router using a LAN cable, and set the router to a key made only by ciphers with no letter, and set the new key on kindle, PC etc. to connect.
Regards.
Ginko.
SOURCE: changed my password on my hotmail,my phone wont
If that is the case, you just have to reboot your phone.
SOURCE: my wifi on my phone wont turn on
did you double check that you don't have it in airplane mode?
