Question about Ovens
Oven temp light stays on even when oven is turned off and cold
    Master:
  • 745 Answers
Faulty oven thermostat, replace it
Posted on Dec 08, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: oven not heating
i have had this problem twice. once was the heating element actually had shorted out because the little ceramic holders had broken, this necessitated getting new element. can be checked out with an ohmmeter by yourself or by taking element into appliance repair place. the other time, it was that the manual reset switch had tripped after a self-clean cycle. actually at the moment, that has happened again- design flaw perhaps in the RSD30 range?
so anyone who can tell a reasonable competent refrigeration/HVAC technician where the manual reset switch is would be appreciated.
Posted on Nov 05, 2007
Tony Coultrip
  • 183 Answers
SOURCE: Gas oven not heating to temp
The fault is either the capillary has fallen away from back or it is a faulty thermostat.
Regards
Advisor
Posted on Nov 17, 2007
Anonymous
  • 123 Answers
SOURCE: Temp probe indicator stays on
If you’ve accidentally switched the oven control on your GE oven from Fahrenheit to Celsius (or vice versa), it can seem like an oven control problem; the keypad will accept some temperature selections and not others. Easy enough to switch back to the way you want it– this excerpt from your owner’s manual explains the technique:
Your oven control is set to use the Fahrenheit
temperature selections but you may change this
to use the Celsius selections.
Press the BAKE and BROIL HI/LO
pads (on double oven models use
the upper oven controls) at the same
time for 3 seconds until the display
shows SF.
Press the BROIL HI/LO pad. The
display will show F (Fahrenheit).
Press the BROIL HI/LO pad again. The
display will show C (Celsius).
Press the START pad.
NOTE: On double oven models the new setting
will be displayed for both ovens.
Posted on Feb 13, 2008
Anonymous
  • 212 Answers
SOURCE: Main oven doesnt heat up. But temp light is on.
replace heating element
Posted on Jun 22, 2009
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: CANDY OVEN
It will be the oven element that has failed, you need to fit a new one.
It is located at the rear of the oven compartment.
Posted on Feb 22, 2010
Testimonial: "GR8 JOB HAVE ALREADY SEARCHED ON THE NET BUT THIS CONFIRMS. NICE ONE CHEERS."
When I light my oven, it stays on full all the time. Is it the thermostate
I'd recommend buying an oven temp dial to stick in your oven to verify the actual temp. Then you can turn on the oven using a lower setting and write down the temp for the setting. Then as you slowly adjust the setting higher and higher, note each temp. If it doesn't show a consistent increase of temp for each setting, you may need it calibrated or replaced. Good luck!
Sep 18, 2014 | Ovens
Nardi oven F86
I have a Nardi f86 but I Don't know how can I used the Bud ( knob ) of the furnace, please can you help me, thanks verf much, greetings of ANNE
Jun 03, 2013 | Ovens
My OR90 multi-function freestanding cooker turns off often even when not up to temprature and often stays off for upto 25 mins
check that the oven thermostat probe inside the oven has not been dislodged and is touching or very close to the oven element
Mar 13, 2012 | Fisher and Paykel Ovens
Main oven not heating up , fan running ,temp light on but no heat
I suspect that the oven element has failed, to check this, remove cover at rear of oven compartment, there you will see the round oven element, it should feel hot after turning oven on to heat, if it is cold, replace it.
Feb 28, 2011 | Stoves 720EF Electric Double Oven
Does not turn on always while cooking and temp. doesn't stay even
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Oct 10, 2010 | Ovens
Have a viking professional oven and it takes too
A weak oven ignitor will cause this problem. even though it eventually lights the temp has dropped considerably so you don't get consistent temp. turn the oven on and listen for the burner to light. should light within about 2 minutes. if not replace oven ignitor(s)
May 20, 2010 | Viking 27" Professional Select Built-in...
Oven temp stays high and doesn't keep even temps
Have you cleaned your oven lately? Is it dirty inside?
With the oven cold. Look inside for a temperature probe. It usually looksl like a medium piece of copper tubing. Make sure it is clean.
Sounds like your thermostat is causing the problem which might be because of a dirty sensor.
Oct 15, 2009 | Ovens
Fan and light work, oven stays cold
one of three things are possible:either you are missing part of your 240volts at input power,or a bad neutral power wire to heating element,an oven temp control,or the thermocouple that controls oven temp
Aug 22, 2009 | Ovens
Oven will not stay on
I used what Charlie recommended ...” post-it” as insulation
And works PERFECTLY….
I have a Kenmore oven Clock…( built in the wall)
Thanks Charlie…you are a Genius!!!!
Jul 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Cuts out over 100deg Celcius
the oven cut out stat may be cutting out to early first try this, it should be mounted at the top of the oven unit.
Jun 23, 2007 | Baumatic B180 Electric Single Oven
Ovens Logo
Top Ovens Experts
Marvin
Marvin
Are you an Oven Expert? Answer questions, earn points and help others
