Tools & Hardware - Others Logo
Sue Drescher Posted on Nov 11, 2019
Can’t get staple to come out - Tools & Hardware - Others
Jason hayden
Level 1:
Habit-Forming:
New Friend:
  • Contributor 10 Answers
  • Posted on Nov 13, 2019
Jason hayden
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
10
Questions
0
Helped
5973
Points
13
Didnt give much info to go on lol. Make /model and a little more detail on your issue will be needed before anyone can try to help you
Arrow TacMate Staple Gun Model T50X1220. I just purchased it new. I loaded it with Arrow T50 staples, numerous sizes, but nothing exits the gun.
Question edited for clarity and typos.
Question moved from Air Tools and Compressors.
It is always a misfired staple jamming at the end or incorrect loading of staples.
How to Troubleshoot a Staple Gun
Hunker https://www.hunker.com > how-to-troubleshoot-a-stap...
Troubleshooting a staple gun such as the Arrow T50 is often as simple as unclogging a jam in the mechanism. This happens when a staple lodges inside the tool, ...
Common Staple Gun Problems and How to Fix Them
Tool Nerds https://toolnerds.com > common-staple-gun-problems
Arrow PT50 - that utilizes external power to propel the staples, meaning effortless trigger operation. Misfiring or Clogged Hammer. The signs of a ...
why-aren't-my-staples-going-all-the-way-in-when-i-use- ...
Arrow Fastener https://arrowfastener.com > arrowfastener
Reason #3: Not keeping the staple exit point flush to surface when firing. ... Duty Staple Gun takes more grip strength to fire than our TacMate staple gun.
What.size staples needed for arrow fastener ct50
It accepts two rows of T50 staples.
T50 type 17/32" Ceiltile staples
3answers
How do I reset to just basic adding
Dont know what you are saying.
Basically turn it off and on if your stuck.
1helpful
2answers
What Staples does a swingline 34301 Electric Staple Gun take?
That's an easy one
Use the Arrow 600 series staples. heres the link to the different sizes available.
http://www.arrowfastener.com/catalog/supplies/staples/600-series
Good luck and don't forget to rate me :)
Staple is jammed
Open the area where more staples are inserted, remove the staples, then find the jammed staple. You'll probably have to wrench it out with pliers. Then insert the good staples and try again.
Lost the spring that holds the staples in model strapgun 12-14 how can i get new 1
No spring needed
Turn staplegun upside down. At
rear of tool, squeeze latch on
end of staple channel (see Fig-
ure 4). Pull staple channel cover
out of staple channel until it stops
(see Figure 4).
3. Drop staples into staple
channel. Make sure staple
points are facing up (see
Figure 4).
4. Slide staple channel cover
back into staple channel until it
2helpful
How do you adjust the staple size to load 1/2" or 1/4" staples?
Staple guns can use a variety of staples; the width of the staple is fixed, the lengths vary from 1/4" up (usually in 1/8" increments). You don't need to adjust the staple gun for the different lengths, just be sure the width fits your gun since some manufacturers have used brand-specific staples.
There are also a variety of staple types; there are staples for ceiling tile, electric wire, window screening, etc. My favorite staples for wood have the tips cut on a sharp angle, they penetrate wood well. Some staple types require a particular gun, I have a gun that shoots only round-top staples for small cables like phone & thermostat wire.
190helpful
10answers
3answers
Staple Gun Troubleshooting
Most of the staple gun models lack an "anvil" — the metal plate with curved slots that office staplers use to bend the legs of the staple inwards and flattens them against the paper. Staples set with a staple gun retain their straight legs, and are held in place only by static friction of the legs against the compressed surrounding material, much like common nails. Indeed, some staple gun models can handle brads and nails as well as staples. Some staple guns also use divergent point staples where the legs twist as the staple drives into the surface providing superior holding power.
Top Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
