The mixing ratio for Apparent Ravage Herbicide
DIRECTIONS FOR USE RESTRAINTS: DO NOT spray when rain seems likely to occur within 4 hours. DO NOT spray when weeds are wet with dew or rain or under stress from drought, low soil fertility, extreme cold or water logging. DO NOT spray outside recommended crop growth as crop damage may result. DO NOT apply to crops or grass pastures with clover, lucerne or medics. DO NOT apply to legume pastures. DO NOT apply to plants suffering from stress. CROP & SITUATION WEEDS CONTROLLED STATE RATE CRITICAL COMMENTS Barley, Commercial Rye, Oats, Triticale, Wheat From early tillering stage (Zadoks 21) Capeweed, Charlock, Common Ice-Plant, Seedling Docks, Doublegee (Threecornered Jack, Spiny Emex), Hexham Scent (Melilotus), Mustards, Soldier Thistle, Sorrel Seedlings, Tares, Tree Hogweed, Turnip Weed (Rapistrum rugosum), Vetches, Ward's Weed, Wild Turnip (Brassica tournefortii), Wireweed (Hogweed) All States 1 L/ha Spray when most weeds are in the 2 to 4 leaf stage. In some instances suppression only of Wireweed (Hogweed), Capeweed and Wild Radish will occur. Seedling Cotton Thistle, Fat-Hen Tas only Barley, Commercial Rye, Oats, Triticale, Wheat From early tillering stage (Zadoks 21) until the fully tillered stage and before jointing occurs (Zadoks 30) Cotton Thistle to bud formation Tas only 1.7 L/ha Spray when most weeds are still in the young rosette or seedling stage. Note: Wild Radish may need to be resprayed (with 2,4-D or MCPA) if future germinations occur after spraying. In some instances suppression only of Wireweed (Hogweed), Hoary Cress and Climbing Buckwheat will be obtained. Mintweed, New Zealand Spinach Qld, NSW only Doublegee (Threecornered Jack, Spiny Emex), Wireweed, Vetch, Variegated Thistle, Tares, Sunflower, Hexham Scent (Melilotus), Docks SA only Capeweed, Charlock, Chickweed, Climbing Buckwheat (Black Bindweed), Clover, Common Ice-Plant, Seedling Docks, Doublegee (Three cornered Jack, Spiny Emex), Fat-Hen, Hexham Scent (Melilotus), Seedling Hoary Cress, Mouse-eared Chickweed, Mustards, Narrow-leaved Plaintain, Saffron Thistle, Spurry, Swinecress, Tares, Tree Hogweed, Turnip Weed (Rapistrum rugosum), Variegated Thistle, Vetches, Wild Radish, Wild Turnip (Brassica tournefortii), Wireweed (Hogweed) QLD, NSW, Tas, WA, Vic only SA only 1.4 L/ha Barley, Commercial Rye, Triticale From early tillering stage (Zadoks 21) until the fully tillered stage and before jointing occurs (Zadoks 30) Volunteer Peas SA only 1 L/ha plus 60 mL/ha 500 g/L Dicamba Apply when most peas are 5-7 cm high. Oats, Wheat From early tillering stage (Zadoks 21) until the fully tillered stage and before jointing occurs (Zadoks 30) 1 L/ha plus 120 mL/ha 500 g/L Dicamba . CROP & SITUATION WEEDS CONTROLLED STATE RATE CRITICAL COMMENTS Per Ha Per 100 L Per 15 L Knapsack Grass Pastures Bathurst Burr, Caltrop (Yellow Vine), Chicory, Crofton Weed, Cudweed, Dandelion, Deadnettle, Fleabanes, Fumitory, Groundsel, Heliotrope, Inkweed, Mintweed, Nettles, Noogoora Burr, Pennycress, Potato Weed, Ragwort, Ripplewort, Shepherd's Purse, Smart Weed, Soft Rush, Stinkwort, Thistles including Cockspur, Scotch (Spear), Slender, Star, Variegated, Wireweed (Hogweed) All States 2.8-4 L 190 mL270 mL 60 mL Use the higher rate on larger weeds. Cotton Thistle Tas only Buttercups, Hoary Cress seedlings, Horehound, Khaki Weed, PurpleTop, Veined Verbena All States 4-7 L 470 mL 100 mL When necessary a second treatment may be made after 4 weeks. Turf Bindy-eye, Capeweed, Catsear, Chickweed, Clovers, Cotula, Creeping Oxalis, Cudweeds, Dandelion, Dock, Fleabane, Fumitory, Jo-Jo (Onehunga), Lambs Tongue, Medics, Mustards, NarrowLeafed Plantain, Pearlwort, Pennywort, Peppercress, Radish, Scarlet Pimpernel, Slender Thistle, Soldier Thistle, Spear Thistle, Toad Rush, Variegated Thistle, Wild Turnip, Wireweed (Hogweed) All States Golf Tee, Golf Green: 100 mL in 15 L water per 150 m2 Bowling Green: 900 mL in 200 L water per 1400 m2 Large Turf Area: (Field, Park, Golf Fairway) 6.5 L in 250-400 L water per 10,000 m2 (1 hectare) Apply to actively growing weeds and moist soil. DO NOT use on Lippia or Strawberry Clover. DO NOT mow turf for two days before or after application or fertilise within 2 weeks of spraying. DO NOT reapply to Buffalo Grass within 12 months. Non-Crop Situations Artichoke, Bindweed, Fennel, Hemlock, Thistle seedlings All States 5.2 L 350 mL 80 mL A repeat spray may be necessary. NOT TO BE USED FOR ANY PURPOSE, OR IN ANY MANNER, CONTRARY TO THIS LABEL UNLESS AUTHORISED UNDER APPROPRIATE LEGISLATION. WITHHOLDING PERIOD: DO NOT GRAZE OR CUT FOR STOCK FOOD FOR 7 DAYS AFTER APPLICATION. HARVEST WITHHOLDING PERIOD NOT REQUIRED WHEN USED AS DIRECTED. RESISTANT WEEDS WARNING HERBICIDE I GROUP Apparent Ravage Herbicide contains members of the Benzoic acid and Phenoxy groups of herbicides. Apparent Ravage Herbicide has the disrupters of plant cell growth mode of action. For herbicide resistance management Apparent Ravage Herbicide is a Group I Herbicide. Some naturally occurring weed biotypes resistant to Apparent Ravage Herbicide and other Group I Herbicides may exist through normal genetic variability in any weed population. The resistant individuals can eventually dominate the weed population if Apparent Ravage Herbicide or other Group I Herbicides are used repeatedly. These resistant weeds will not be controlled by Apparent Ravage Herbicide or other Group I Herbicides. Since the occurrence of resistant weeds is difficult to detect prior to use, Apparent Pty Ltd accepts no liability for any losses that may result from the failure of Apparent Ravage Herbicide to control resistant weeds. MIXING DIRECTIONS: Add the required amount of the product directly to the tank and mix well. APPLICATION: For Boom Application: Apply by a properly calibrated boom spray using not less than 50 Litres of water per hectare unless indicated otherwise in Critical Comments column. For Aerial Application: Apply at least 25 Litres total spray volume per hectare. The aircraft should fly as low as practical under the prevailing conditions to minimise drift. For High Volume Application: Apply a minimum 1500 Litres per hectare. For Knapsack Application: A 15 Litre Knapsack treats 150 square metres. Note: Spray when weeds are young and actively growing. A temporary wilting may be evident in crops after application. If seasonal conditions are unusually late or dry, seek further advice as damage may result from spraying under these conditions. Growers should seek advice before spraying recently released cereal varieties. There is a nil tolerance of pea seed contaminates in cereal grain and less than 100% control of Volunteer Peas could result in dockage. COMPATIBILITY: Apparent Ravage Herbicide is compatible with Flowable Igran*.
THIS INFORMATION IS COPIED FROM THE BOOKLET PAGES 2 AND 3
