Question about Geneva Watches
What battery do i need for my Geneva 5573 - Geneva Watches
    Top Expert:
  • Geneva Master
  • 54,849 Answers
Take your Geneva to a jeweler who will open it, identify the battery type and perhaps install a new one.
Posted on Nov 27, 2019
6ya staff
SOURCE:
Is the back of my generva watch 5573 s a pop off or screw off?
Best to take it to a jeweller as battery replacement if not knowing how can damage the movement. Otherwise a screw back has little notches on the side of the back and a press back is smooth. You will need a back opening knife to open.
Nov 27, 2017 | The Watches
Geneva cuff watch need new crystal
Fixya does not sell replacement crystals.
Jul 20, 2017 | Geneva Watches
How do I fix the pin on a lady's Geneva watch that no longer sets the time or locks down tight?
The "pin" is the stem and they can be delicate. The fix is to replace it.
Sep 09, 2015 | Geneva Watches
How do I change the day, date etc on a GENEVA 7391 watch
read the instruction manual, Geneva Watches with Two or Three Hands
  1. Pull the crown out until you feel a click.
  2. Turn the crown counterclockwise until you have the correct time.
  3. Push the crown back in to set the time.
Geneva Watches with Two or Three Hands and a Date Window
  1. Pull the crown out until you feel two clicks. This second click position allows you to set the time.
  2. Turn the crown counter clockwise until you have the correct time. Push the crown all the way in to set the time.
  3. Pull the crown out until you feel one click. This first click position allows you to set the date.
  4. Turn the crown counterclockwise until you have the correct date. Push the crown back in to set the date.
Multi-Function Geneva Watches
  1. Pull the crown out until you feel two clicks. This second click position allows you to set the day.
  2. Rotate the crown counter clockwise until you have the correct day. Push the crown in to set the day.
  3. Pull the crown out until you feel a second click to set the time or the 24-hour hand.
  4. Turn the crown clockwise until you have the correct time, then push the crown in to set it.
  5. Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
Geneva Chronograph Watches
  1. Pull the crown out two clicks. This second click position allows you to set the time.
  2. Turn the crown clockwise until you have the correct time, then push the crown in to set it.
  3. Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
  4. Stop and start the chronograph by pressing the PA button, located above the crown.
  5. Reset the chronograph by pressing the PB button just below the crown. The PB button returns the chronograph second and minute hands to their original positions of zero.
Automatic Geneva Watches
  1. Wind the mainspring by turning the crown 15 to 20 times clockwise.
  2. Pull the crown out until it clicks.
  3. Turn the crown counterclockwise until you have the correct time, then push the crown in to set the time.
Tips & Warnings
  • Do not set the date or time between 8 p.m. and 3 a.m. to avoid damage to your Geneva watch. The gears sit too close together during these times.
  • If your Geneva watch becomes wet, wipe it dry as soon as possible. Keep your watch away from saunas and hot tubs, as the extreme heat diminishes the watch's water resistance.
Read more : http://www.ehow.com/how_6134550_set-date-time-geneva-watch.html
Jul 13, 2015 | Geneva Watches
Geneva watch bracelet
I Have a Geneva Made Pga Tour Partners Club watch that needs a new band and I have not been able to find one.It is a special band and the PGA partners club says they are no longer available and were not helpful in finding a band.
Apr 01, 2008 | Geneva J06345 Wrist Watch
Hands Stopped
This model watch uses two battery, an lithium battery is for digital and there is another silver oxide battery which were installed beneath the lithiem battery, all you need to do is remove the lithium battery then replace the silver oxide battery, the battery # is 377.
Tsai
Dec 07, 2006 | Kenneth Cole Reaction - REACTION DIGITAL...
Watches Logo
32 people viewed this question
Top Geneva Watches Experts
Janelle Schoonover
Janelle Schoonover
NOEL
NOEL
Andrew Taylor
Andrew Taylor
Are you a Geneva Watch Expert? Answer questions, earn points and help others
