My re-chargeable speaker will no mlonger hold a charge m(still works when plugged in) I cannot see how to dismantle it to get to the battery. Is it possible to buy and fit a new one?
According to Blaupunkt, they don't want you to open the unit
https://www.manualslib.com/manual/891341/Blaupunkt-Monaco-Series.html
Takeapart for a different Blaupunkt bt speaker here https://www.youtube.com/watch?v=4Pp-XcGkpdY
Looks like the battery is similar to those used in cordless phone handsets.
SOURCE: new battery and alternator. Battery still won't hold charge
Check all your fuses if you had a system failure it could have blown a fuse. I am not sure on your vehicle where the fuse is in the car or under the hood it could also have a relay. You can check your alternator by checking the voltage at the back of the alternator where the big wire bolts on. You should have 14+ volts at the alternator.
SOURCE: blaupunkt antenna connection !
Yes - adapters are available in stores & online. Try here:
http://www.bluespot.co.uk/install.asp
SOURCE: Blue light on, battery won't charge, unit new 12/14/09
rechargeable batteries are definitely a better bet. I have used many Wii battery packs and chargers, none seem to last very long.
Testimonial: "Thank You"
SOURCE: Black and Decker battery charger does not work.
Black & decker chargers and bulbs for the light are JUNK..Don't waste your money on their products.I have 2 chargers for the 24 volt batts-1 is only 2 months old-It blew the fuse {soldered to the circuit board} I'm putting in a fuse holder but don't know the amp of the fuse-I'm starting with a 1 amp slo-blo and going up until it works or goes up in smoke..I had loads of problems with this B&D 3 piece set---It's only 1 year old..Total waste of money..
I've dismantled and removed battery, just trying to find a replacement.
