Your lcd is bad,this is common with most Imacs .A faint line will appear from top to bottom then it will multiply over time.Apple had moved to a different manufacturer after a number of incident similar to yours.This is also happening on the G 5 as well.There fix is to replace the Lcd the Inverter and the Lcd Cable.
Good Luck
Its a hardware problem with your monitor, and it most likely won't go away. If its a laptop and its really bothering you, you can have the LCD panel replaced for $500 or more.
Apologies, my reading skills are lacking apparently. In the case of this particular desktop you may find you can replace the lcd panel yourself. Ebay has a selection of different sizes of replacement panels, and the monitor will either unscrew from the back, or pop apart from the front.
It is going to be a lot of effort for the magnitude of the problem.
IT'S A DESKTOP MODEL
