Question about Dryers
Leland motor Ser no 306411c14 can it be reversed with a drum controller
Leland Yee arrested in California
this source says yes: http://www.foxnews.com/politics/2014/03/26/california-state-senator-arrested-in-fbi-sweep/
Mar 27, 2014 | Computers & Internet
HOW DO I TAKE APART MY DELTA 4578-LHP TO FIX A LEAK?
Were you able to figure out how to take the Leland apart? I'm wondering the same thing, Thanks
Oct 24, 2010 | Delta Leland 4578-LHP Two handle Lavatory...
Will not stop filling water
Your fill hose that runs off the drum to the fill control controller on the front panel either has a leek an needs replaced or the controller its self need replacing, the line is cheaper, also look on the drum were the line go to, make show there is no leaks, this is a low presser an vacuum line,
Nov 26, 2009 | Washing Machines
Looking for inf on Heat Controler Inc. Fan coil
What I would suggest if you plan on replacing this motor your self, would to take motor out and take it down to an appliance parts house and pick up a 1/4 hp. motor that will work. If the amperage is close and the shaft diameter is the same, you will save some money with an after market or universal motor. Use a long Allen wrench to loosen the blower wheels and bolts if it has them on the shaft, mark the wiring so you know where the new wire goes, and install in reverse of removing. TURN off POWER!
Good Luck,
Sincerely, shastalaker7
ps Allen wrench are for the set screws on both shafts.This motor can be tricky to remove.
Oct 26, 2009 | Heating & Cooling
Dryer Motor won't always start Model FSE747GES
Too much drag on the Drum. Try lubricating the rollers that the drum turns on. Check the belt tensioner pully...lubricate that as necessary. If Drum still turns very hard after this then take belt off of motor and try turning drum. If drum turns easily then replace motor.
Nov 24, 2008 | Frigidaire FDE336RE Dryer
Dryers Logo
Top Dryers Experts
Marvin
Marvin
jimorris77
