Question about Boating
My minkota 101lbs 36 volt vantage motor stopped working while i was using it and had to take it off of boat because i could not even raize motor
5 Suggested Answers
6ya staff
SOURCE:
Johnny G14
  • 8 Answers
SOURCE: my brother inlaw got a minkota 40ta all terraine
I would check the battery. If you're using an old or under charged battery you will loose power for sure. Make sure you're also using a 12v deep cycle marine battery as this will ensure proper operation and a longer battery life.
Posted on Sep 07, 2009
Bobby Barker
  • 4 Answers
SOURCE: diagram of 36 volt hookup for trolling motor
To get 36 volts, number batteries 1 thru 3. connect pos 2 to neg 1, connect pos 3 to neg 2, connect pos 1 to trolling motor controller and neg 3 to ground on trolling motor.
This is only a solution for 3 battery system.
For 4 battery system, connect 4 to 3 pos to pos and neg to neg.
budman772357@embarqmail.com
Posted on Nov 12, 2009
Donald Dusskie
  • 12 Answers
SOURCE: mini moto atv 36 volt will not run
it probably is the interlock switch/ the black square with 2 small green wires and to large reds.replace that and should run.just bypassed mine and know it works.have fun
Posted on Jun 01, 2011
jsbenson
john Benson
  • 184 Answers
SOURCE: 24 volt trolling motor (motorguide) not working.
Loose /corroded connection at the batteries will do this. Likewise loose connections between batteries and plug.
Posted on Jan 01, 2015
I have a eventide 55hp motor but it does not charge the battery.I do have about 36 volts AC from the flywheel.The connector block has four connector screws.
Please Check Your Voltage regulator.
You May Be able To See Visually If It has Overheated Inspect It.
Check All Earth Connections
Jan 07, 2018 | Light Outboard Motor Boat Bass Fishing...
CAN i CHARGE A 36 VOLT BATTERY WITH A 24 VOLT CHARGER?
No of course not.
The charger has to be the same as the battery it is charging. On BIG batteries, it also has to have the power to handle the higher amps as well.
  • 36 Battery Charger Volts - 36 Battery Charger Volts - Deals! Ad · www.HomeGardenPro.com 36 Battery Charger Volts - Deals! Your Home, Your Style - Redefined.
    Handpicked Collections · Great Deals - Low Prices
  • 36 Volts Battery Charger ' Calibex.com Ad · www.Calibex.com/Electronics Cheap Prices and Huge Selection 36 Volts Battery Charger on Sale!
  • 36 volt battery charger in Batteries & Chargers ' eBay www.ebay.ca > Search > 36 volt battery charger Find 36 volt battery charger and 36 volt battery from a vast selection of Batteries & Chargers. Get great deals on eBay!
  • 36 Volt Battery Charger ' eBay ebay.com Find great deals on eBay for 36 Volt Battery Charger in Forklift Batteries and Chargers. Shop with confidence.
  • 36 Volt Battery Chargers ' Kijiji: Free Classifieds in ... www.kijiji.ca > Ontario Find 36 Volt Battery Chargers in Canada ' Visit Kijiji Classifieds to buy, sell, or trade almost anything! Used cars, pets, jobs, services, electronics, homes, boats ...
  • 36 Volt Battery Chargers - Electric Scooter Parts www.electricscooterparts.com/36vchargers.html 36 Volt Battery Chargers for Electric Scooter, Bicycle, Pocket Bikes, and Go-Karts. We have 36 Volt (36V) battery chargers in stock.
  • 36 Volt Battery Charger ' Kijiji: Free Classifieds in ... www.kijiji.ca > Ontario Find 36 Volt Battery Charger in Canada ' Visit Kijiji Classifieds to buy, sell, or trade almost anything! Used cars, pets, jobs, services, electronics, homes, boats ...
  • 36 Volt Battery Charger eBay
    Sep 20, 2016 | Health & Beauty
    Bosch 36 volt flashlight bulb doesnt last
    Here is what I have done for now. I was able to pick up a 24 Volt 10 Watt G-4 Base bulb at a local Boat USA store. So far so good. I had it running for 6 hours straight with no issues and still working.Finding a 36 Volt bulb replacement has been difficult and the bulbs don't last.
    Dec 18, 2013 | Bosch 2610948135 36 Volt Replacement...
    My motor guide trolling motor died . It was on the new boat that I bought in 2011 . Checked the breaker fuse and it's good, tested the wiring with a volt meter couldn't find anything. Could it be the micro...
    do you have it hard wired to pos and neg or does it have the 3 prong plug in switch ..if 3 prong its for a 24/36 volt motor wont work on 12 volt less you have the 12 volt plug
    Oct 16, 2013 | Boating
    Riptide RT65 24 volt with auto pilot goes nuts.
    your magneto is shorting [ arcing on high needs, openup and replace magneto. call minkota and order a new magneto for your model, unless under warrantee.
    Apr 13, 2010 | Minn Kota Riptide Sp Saltwater 70 Bow...
    Wanting to install motorguide 24v trolling motor in boat, will it work on just 12 v system
    No. you can put in extra batteries and use it, but you must remove you charging system from them to use it that way. Not really practical.
    Mar 21, 2010 | Electrical Supplies
    My brother inlaw got a minkota 40ta all terraine trolling motor that is supposed to produce 40 pounds of thrust. it does not seem to produce even close to that. is it possible that the motor is turning the...
    Apr 18, 2009 | Minn Kota Edge 40 Freshwater Bow Mount...
    Diagram of 36 volt hookup for trolling motor, i have a factory 24 volt wiring in my boat and I need to turn it into a 36 volt please help thank you
    Mar 01, 2009 | Minn Kota Boating
    Boating Logo
    24 people viewed this question
    Top Boating Experts
    ray gallant
    ray gallant
    Andrew Taylor
    Andrew Taylor
    Tom Chichester
    Are you a Boating Expert? Answer questions, earn points and help others
