Possible free manual online, as Rheem apparently also produces Ruud models:
https://www.theacoutlet.com/documents/Installation-Guide-Rheem-RANL-RAPL.pdf
SOURCE: ruud achiever 10 seer air conditioner
It sounds like your condenser fan motor may be locked up or the capacitor that helps give the condenser fan motor a kick to get it started may be defective. Try turning your system on and using a long screwdriver try to push the fan blade on the condenser fan motor to see if it will run normally if you give it the starting boost it needs.If it does run at full speed and doesn't over heat or start and then slow down then you probably only need to replace a simple 10-12$ capacitor. If it barely turns, makes an odd humming sound or overheats etc. then you will have to replace the condenser fan motor. This is assuming that the outdoor condenser has the 220v supplied and the 24v supplied to the compressor relay, that the compressor relay is engaged and suppling 220v to the condenser fan motor.
SOURCE: Old Ruud Air Conditioner
all heat pumps follow the same schematics universal get a hold of any heat pump schem and you should be able to aplie it to yours
SOURCE: ruud air conditioner model uamc 060 jaz
check breakers first,then fuses in disconnect if applicable,then capacitor.
SOURCE: I NEED AN OWNERS MANUEL FOR A SINGER SEWING MACHINE MODEL NUMBER
http://safemanuals.com/user-guide-instructions-owner-manual/SINGER/QUANTUM%209940-_E
Click on Download the complete user guide (9002 Ko)
from right side of the window
SOURCE: i need parts for everstar portable air conditioner
I have lost the exaust tube and the attachment that hooks up to the back of the unit to the tube. Where can I buy these parts?
