Question about Ricoh Office Equipment & Supplies
Ricoh 305 color lever undetected - Ricoh Office Equipment & Supplies
Error sc 305 ricoh aficio sp 420dn ?
The SC 305 on a Ricoh SP 420DN is related to a AC bias charge error for the magenta color.
The machine sence there is a charge current that is less then
200 ?A is detected.
There are four reasons why this may happen.
• Defective charge roller
• Defective connectors
• Disconnected harness
• Defective high voltage power board 1
Follow this procedure, and see if that does the job.
1. Check the connectors.
2. Replace the PCU for magenta.
3. Replace the drum positioning plate.
4. Replace the high voltage power board 1.
Let me know if you need more info, part numbers and stuff like that.
Jul 09, 2017 | Ricoh Office Equipment & Supplies
Sc 305 dsc 224
The error code sc 305 is a charge corona wire cleaner error. Has the pcu or charge corona assy been replaced or removed for any reason?
Oct 26, 2013 | Ricoh Aficio 1035 Copier
Replace Color Dev. Unit (Type B) alert
You stated message said replace dev units. Why did you replace the PCU's? There is a difference. The color pcu's can go into any color slot but the deverloper units can only go in one slot. The dev units have a u shaped green plastic part on the front of them and just slide out. The pcus have a little lever and have to be released.
May 26, 2009 | Ricoh Aficio CL7200 Laser Printer
Light blue lines in the color pages
Yes :
You should replace the PCU if prints show any of the following symptoms.
  • Colors are missing, faint, or partially blurred.
  • Toner smears appear.
  • White or color rivers appear.
  • White or colored streaks appear.
    1. Important: Switch off the device and disconnect it at the mains.
    2. Open the right side cover.
    3. Pull the green levers as shown to release the inner cover.
    4. Lift the inner cover upwards.
    5. Squeeze the green lever on the black PCU.
    6. Pull the unit carefully out of the device and dispose of it in accordance with your local environmental policy.
    7. Place the new PCU on a flat surface.
    8. Peel off the tape from around the new PCU.
    9. Remove the top cover from the PCU. DO NOT remove the bottom cover at this stage.
    10. Rest the new PCU in the device as shown.
    1. Push the PCU into the device while holding the bottom cover. You will hear a click when the PCU has locked into place.
    2. Lower the inner cover.
    3. Push the two green levers as shown to secure the cover.
    4. Close the side cover.
    5. Connect the device at the mains, switch it on and wait for the self-test operation to finish.
    6. Please remember to rate all users who assist you for free :)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 07, 2008 | Ricoh Aficio CL3500N Laser Printer
How to clean lens on our ricoh CL3500N Laser printer
Toner spills can be cleaned with a cotton pad and alcohol. If excess toner appears do the following:
Aug 07, 2008 | Ricoh Aficio CL3500N Laser Printer
Install Paper Support Part
ta benDe z25 yazıcı varda biTane cd açıLıyoR next yazısı qörünmüyoR yani yükleyemiyoRum neden oLDuqunu söeLermisiniz TşkLer r
Mar 24, 2008 | Lexmark JetPrinter Z25 InkJet Color...
35mm Film Camera Ricoh XR-2
You can replace it with the available lever.Most of the cameras lever can suit
Feb 23, 2008 | Photography
Ricoh CL2000N
open rt. door remove the waste toner ant the color and black drum units undo the green screws and slide out, watch out for the green swutch an the left side of transfer unit thurn it up so as not to break it both going in and out
Jan 22, 2008 | Ricoh Aficio CL2000N Laser Printer
Ricoh Aficio MP C1500SP - functional error SC202
call ricoh serviceman he/she can fix it.
Defective tank full sensor
• Tank full lever bent or broken
• Incorrect ink suction
1. Check the harness of the tank full sensor.
2. Replace the GJ engine.
3. Replace the maintenance unit.
• The position of the tank full lever
does not stay at the tank full position
after ink initialization or air releasing.
• The position of the tank full lever is
not detected at ink suction.
Aug 19, 2007 | Ricoh Aficio 1515 All-In-One Laser Printer
18 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
