SOURCE: Tanita, the Ultimate Scale
The scale may have instructions on the bottom of the scale. (Example for the Tanita: The Ultimate Scale w/ the body fat analysis). The instructions on the back state the following steps: Step 1: press both the "Set" and the triangle buttons. Step 2: press the "triangle" button until you select the appropriate weight measurement (a) kilogram, (b) stone lbs or (c) lbs. Step 3: press the set button.
SOURCE: I have a brand new scale that does not display
I have the same problem - brand new scale that does not display. New batteries are installed correctly. What is the solution?
SOURCE: I recently purchased a Soehnle
Look around and see if it has a reset button ...and reset it to factory settings ..Probably happened with it ..or cause it repeated you are doing something wrong when you set it .....probably you lock it in the last read ..cause it indicates the same measurement ..So ..all devices like that have to have a reset button ...locate it ..(it may be in the menu as a feature..and called different probably ..factory defaults or factory settings ..or reset all ..) and after you engage the reset it will work again ..but ..read the manual carefully and see what are you doing wrong ...
SOURCE: How do I change my 100 gram weigh max scale from
a scale is calibrated at half it's capacity. when you use a 50 gram weight to calibrate it, it can still measure 0-100 grams properly.
SOURCE: how do i program prices per lb and oz on quantum scale
You can go to Hobart.com:
http://www.hobartservice.com/main/default.aspx
and create a new user and download a manual.
