There are three main things to tackle when cleaning a hot tub or whirlpool bath. Those things are:
1. Bacteria
2. Grease
3. Grime and dirt
To address all three of these issues you'll likely need separate products. There are liquid versions of the degreaser and cleaner, and there are tablet versions for sanitizing.
Simply fill up the whirlpool bath with warm water, put the cleaning liquid in the cleaning outlet (or if you don't have this, just pour it into the bath). Put the tablet in the bath and then just run it.
if it is standard shower where you pull the knob up when water is running. the pull knob lifts a flap to shut off water to bottom faucet it proably has some buildup on the flap clean well with some clr or other calcium cleaner like it so the flap gets a clean seal on downspout
There are two types of tub drain stoppers for the delta brand - lift & turn and toe tap.
Lift and Turn: The lift & turn stopper for the bathtub unscrews counterclockwise while in the full up position.
Toe Tap: The toe tap stopper does also but if the cap may unscrew from it before the entire stopper comes out. In that case, there is a nut that is now exposed and can be accessed to unscrew the assembly.
If either of these is "spinning" without unscrewing, the threads are stripped and you would need to exert upward pressure while unscrewing in hopes of uncoupling this from the bath waste. If that doesn't work you would have to unscrew the bath waste flange from the drain pipe. This will require access under the tub. I hope this answer the question for you. Thank you for using FIXYA. Jeff
Lift and Turn:
Toe Tap:
Your question is: You have a claw foot bath to install in a tiled bathroom. How do you fix the bath to the floor so it is secure and doesn't move?
A little clear silicone caulk under each claw is my favorite method. Locate the tub in it"s final position. Set up the drain and water connections so that you can complete them without moving the tub. Lift each end in turn just a bit and aply some caulk, you may need a helper. Wipe off the excess. Then hook up.
Feel free contact me again! Please give me a rating here at fixya.com before you sign off Thank you, Harvey your Master Plumber
whirlpool tub has jets that circulate the water, where an air bath uses bubbles that rise gently from the bottom of the tub. Whirlpools are typically used for therapy, air baths are used for a much gentler experience. Air baths can be used with aromatherapy/essential oils. Both offer a spa-like experience.
