Sony Cybershot DSCW80 7.2MP Digital Camera with 3x Optical Zoom and Super Steady Shot  Logo
Posted on Sep 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LENS PROBLEM Lens keeps zooming in and out when I turn it on. After 4 times, the lens goes back in and it says on the screen, "Turn the power off and on again". Then it does the same thing when I turn it off and back on. Also, the shutter is not closing however it's also not all the way open. Almost half way but more open than closed. Please help!!!
Anonymous
Level 3:
  • Master 428 Answers
  • Posted on Sep 18, 2009
Anonymous
Master
Level 3:
Answers
428
Questions
0
Helped
108432
Points
1406
The slightly open shutter is the reason for this problem. Thank God you mentioned it.
Solution: Try with your fingers to shift the shutter “blades” back and forth to see if they move freely. If they do no move freely it maens the shutter “blasdes” and stuck by particles/dust/something. So you just continue to shift them like that untill they are free again. Once they are free turn your camera back on and it should perform as normal.
3 Related Answers
Anonymous
  • 262 Answers
  • Posted on Nov 12, 2009
SOURCE: zoom lens stuck out
that error code indicates the the Lens of teh camera is already defective., In most cases if the lens is stuckout or stuckin camera will not stay On or It will not Turn On at all. For this case you need to call Tech support to send you camera for repair toll free 1 800 235 6325 extension 12
Anonymous
  • 421 Answers
  • Posted on May 02, 2010
SOURCE: My lens shutter is stuck half closed and will not
If the lens is stuck out then you will find it is usually one of a few reasons.
1. Check the batteries. (obvious I know).
2. The camera has been dropped or knocked.
3. The camera has grit or dirt in the lens mechanism.
Providing the batteries are ok then 2 and 3 usually mean a professional repair. The lenses tend not to be something that the average home user can remove and take apart. The cost of repair also might be more than the camera value so you will need to find a good repair shop near you and get a quote.
Anonymous
  • 11967 Answers
  • Posted on May 25, 2010
SOURCE: zoom error on fujifilm finepix J30/35 how can i fix it?
If this is a brand new camera, it should be under warranty...why do you say yours is not?
How to fix a Fujifilm FinePix S4000
some times small particles or grit get into the lens housing and prevent movement... try holding the camera vertical with the lens pointing down and tap the back of the camera firmly a couple of times... keep the camera in this postion and switch the camera ON and OFF a couple of times to try and loosen any foreign particles... you may have to repeat this procedure several more times before you achieve success...
1helpful
When I try to power up my Olympus C-5060 5.1 MP wide zoom camera, the lense will extend, there is a pause, the lense goes back in, it beeps 18 times, it tryies again and beeps 18 times again and shuts...
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
7helpful
My 71275 is stuck in the full zoom position and won't stay on...
1helpful
Lens error restart camera
This is a common problem with with cameras with retractable zoom lens .
Heres a few thing you should try :
Fix #2: Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. If you get another type of error message this may mean you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
TO AVOID THIS PROBLEM AGAIN : Keep away from dust, dirt, grit, sand and any camera bag that has loose fibres (clean it before use).
If this helps you, please vote...thankyou and good luck!
8helpful
Lens error 0x02110000
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one). TO AVOID THIS PROBLEM AGAIN : Keep away from dust, dirt, grit, sand and any camera bag that has loose fibres (clean it before use).
Len
camera lens has problem.
need repair lens
mydc digital camera reapir
10helpful
10answers
Problem
I had the same problem and fixed it.
The problem is related to the lens not working properly and jammed up.
When powering on the camera, the focus goes in and out and the lens spin and then the message is displayed to turn camera off.When I turn the camera off, I noticed the lens did not fully hiberate into the camera like it did before the error message.
So to fix the problem I did the following:
Turn the camera on, when the lens extended out, I slightly rotated the outer most lens clockwise and counterclockwise to free the lens from the jammed position.
The error no longer appeared and the camera stayed-on.When I shut the power-off the lens completely hibernated again like normal.
Hope this helps.
Pete
2helpful
Zoom error
I had the same problem with mine and I tried several suggestions, BUT the only one that has worked is to gently grab the lens, pull it out as far as it will go until fully extended. While keeping it extended turn the lens to the right until you hear a click. Once you hear the click, release the lens and turn the power button on and then back off again. This should take care of the problem. A word of warning. ALWAYS make sure your fingers do not touch the front of the lens when you power on the camera. Even the slightest bit of obstruction seems to make the problem reoccur. Another note. I had tried this several times until I finally heard the click, so please don't give up on it, just keep trying. This will work and it will save you a lot of time and money having it fixed.
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
