Hi, You must go to bios and change the booting sequence to CD drive and you need to check if the cd from which you are trying to install windows xp is a boo table one you can do so by inserting the cd in a different system and try. IF not then check if your cd drive is working by inserting any cd in it.
Do you have any extra things plugged into the usb ports? (external hard drive,Ipod,Flash drive) anything like that can sometimes cause pc's to hang at boot they will try to boot to that device instead of your hard drive
Based on your situation. I suggest trying the following steps:
1. restart the computer and keep pressing F8; Use Last Known Good Configuration.
2.If the issue still occurs after that, I suggest testing if we can boot from a Windows XP disk. If so, please install Windows XP on another partition and access your important data.
3. After backing up those data, you can use Windows XP disk to format the drive and reinstall your preferred operating system.
4. However, if we cannot boot from a Windows XP disk, the issue can be caused by incorrect BIOS settings or damaged hardware. I recommend contacting your computer manufacturer to check BIOS and hardware.
To access the data on the drive, you can try to install the hard drive on another computer.
Hi, seeing that the interior light stays on you might want to look at the drivers door switch situated either on the "A" or "B" piller where the door makes contact with the body. Once you take it out it might solve your problem. Please keep me up to date with your findings.
Ok, this is a mother board issue. the entire mother board seems to be malfunctioning. the blinking amber/green light is confirming this. the mother board may have some fried circuitry and it will have to be replaced in this situation.
I would recommend extracting the mother board and stripping it. look for any discoloring factors that will lead to a burn out location. this will direct you to the necessary repair zone.
Hey jp62388, According to information provided by the manufacturer, this model TV should have a built-in NTSC/ATSC and QAM tuner. These should allow you to receive locally broadcast digital TV signals without the use of a set-top box or digital converter box. If you're concerned about your TV's specifications, the most important thing you'll need to look for is a built-in or integrated ATSC tuner. NTSC is the old analog standard that is to be phased out in early 2009, while ATSC is the new digital standard that is to be used within the United States and Canada as NTSC’s replacement. Should you have any other questions or concerns, I'd strongly suggest checking out the FAQ section of the federal government’s official DTV transition website: http://www.dtv.gov/index.html Hope this helps you out. Sincerely, Aaron Go Ahead. Use Us.
