Krups manuals here https://www.krupsusa.com/instructions-for-use/Products/Beverages/Espresso/csc/Espresso
Are you in the USA or Europe?
Testimonial: "Norway"
SOURCE: krups model 467
Means it's time to buy a new machine. This one is worn out, and past its expiry date.
SOURCE: check engine light flashes 3 times and then
If you counted the flashes as you are listing them then this would be a code 33, this code 33 is defined as vechile speed sensor, this is the speed sensor and is located on the transmission, checcck the connection to the sensor and if the connector and the connection is good then i would replace the sped sensor.
SOUNDS LIKE SOME KIND OF WARNING SIGNAL
