Question about Whirlpool Microwave Ovens
F6e8 error code whirlpool combo. Microwave and oven
    Top Expert:
  • Whirlpool Master
  • 2,272 Answers
Anonymous
SOURCE:
Anonymous
  • 1665 Answers
SOURCE: Whirlpool microwave oven
Here is a list of common error codes:
http://www.repairclinic.com/0078.asp
Posted on Feb 02, 2008
bestdarngood
Benjamin Patri
  • 3037 Answers
SOURCE: whirlpool microwave oven model gh5184xpq
Models: GH9177XL GH5176XP GH5184XP GH6178XP GH6177XP
KHHS178L KHHS179L
Microwave will not operate (cook). F7 error code
appears on the display.
Electrical circuit interruption between L1 and Neutral in
the microwave inverter circuit.
Possible reasons:
1. Check door, hinge and cavity front alignment and adjust
as needed.
2. Check the operation of all interlock switches.
3. Check over temperature protector for the magnatron.
4. Check all Cavity Thermostats for closed circuit.
5. Unplug the oven for at least 40 seconds. If this solves
the problem
A. Check the Cooling Fan for proper operation or
blockage
B. Check the resistance of the magnetron thermostat.
It should be 0 Ohms, replace if necessary.
6. Check that the control cable to the 1100 watt inverter
is properly connected to plug P2 on the display PCB
& Adjust or Reconnect
7. If interlock switches operate correctly, replace 1100W
inverter.
8. If problem persists, replace control assembly.
Please let me know if you need any more help or have further questions about anything that I have posted. I would be glad to help
thanks
Posted on Apr 27, 2008
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: kitchenaid double convection microwave /
I'm guessing the model number would be KEMS308GSS0.
In some cases, this is a glitch that can be cured by unplugging it for 1 minutes, then resetting the clock.
In other case, it may be a bad keypad (membrane switch) or control board.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jun 08, 2008
Anonymous
SOURCE: Microwave Oven Door Spring Replacement
Remove the front panel by removing the screws located on the inside of the door (note hold door inplace, since it is heavy and will fall out after screws removed). Unscrew screws located on bottom of plastic retainer (2 each) Remove tension spring. Note 2 are included right and left. Note color of spring on end, different springs for different door types, stainless, black,beige or white. Replace all in reverse order.
Posted on Mar 26, 2009
Kolawole Ayede
  • 327 Answers
SOURCE: 66993 pizza oven microwave oven combo
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Posted on Jul 13, 2010
ERROR CODE F6-EO
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 02, 2016 | KitchenAid Kehu309Sss 30" Microwave...
My whirlpool microwave oven will not power up and shows a code f2. how can i fix it
its an error need to call technical assisstance ..thAT error ranges for faulty temp sensor/probe up to control board ....
Aug 05, 2014 | Whirlpool MH1150XMQ Microwave Oven
Whirlpool mircowave model MH3184XP the display reads F2
There is a problem with the control pad. The membrane, or surface, of the pad may be broken or damaged somewhere, resulting in the F2 error code. This is common for Whirlpool microwaves.
Press "Stop/Cancel" twice and select a new cook program. Press "Start" to begin.
If the error code persists, press "Stop/Cancel" again and unplug the microwave. Wait several minutes and plug it in. If the F2 code appears again, it requires repair.
Replacement membranes can be found online
http://www.appliancepartspros.com/whirlpool-panel-asy-control-8205376-ap3775860.html
but the internals of a microwave are dangerous, having high voltages even when unplugged. With the cost of parts and labour from a service tech, you may be best buying a new oven.
Sep 04, 2013 | Whirlpool MH3184XP Microwave Oven
I have a Whirlpool wmh1162xvs2 Microwave Hood combo. Everything seems to be working fine except it is not heating the food. Please help!
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 =-
Aug 30, 2011 | Whirlpool WMH1162XVS Microwave Oven
2004 whirlpool microwave oven/hood combo made a loud noise and now wont heat food
heatman101
Jun 27, 2011 | Whirlpool Microwave Ovens
My whirlpool mh 1140 xm microwave/ hood combo is not heating. everything else works fine, just the heat. I would rather repair than replace. Help!!
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Mar 08, 2011 | Whirlpool MH1140XM Microwave Oven
Whirlpool Microwave error F3H
F3H Humidity sensor failure 1. Unplug microwave oven or disconnect power.
2. Connect a new sensor to the board (at P5).
3. Plug in microwave oven or reconnect power.
4. If no failure code appears when starting sensor function:
 Replace old sensor.
5. If failure code appears when starting sensor function:
 Replace power supply board.
6. Plug in microwave oven or reconnect power.
Aug 04, 2010 | Whirlpool GH5184XPQ Microwave Oven
F7 ERROR CODE ON GH6177XPS
This is a known problem with this unit, and whirlpool has put out a Service Flash out on this. The reason this is happening is Electrical circuit interruption between the L1 and Neutral in the microwave invert circuit. This has to be addressed by a Tech.
DrakeTech
Dec 24, 2009 | Whirlpool GH6177XPS Microwave Oven
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Microwave Ovens Logo
53 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Ekse
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
