Question about American Standard Plumbing
How to remove and replace pull down hose and head in an american standard kitchen faucet?
Female connector to hold head on is stuck in faucet
Download the BILT app and search for your faucet model. The icon is turquoise with a white nut ( as in nut and bolt).
It will show you step by step nearly everything under the sun. Hope that helps a bit.
Posted on Nov 09, 2019
Anonymous
SOURCE:
Anonymous
  • 171 Answers
SOURCE: kitchen spout leaks
Hi buffy9,
I'm Harvet the Master Plumber.
Your question is: You have an American Standard two faucet in my kitchen and the base of the spout leaks at the base. How do you remove it and replace the washers?
Are we talking about an American Standard two HANDLE faucet or one of the single handle models?
Thank you,
Harvey your Master Plumber
Posted on Oct 17, 2008
Bill Johnson
  • 297 Answers
SOURCE: how to replace sprout seal kit in american standard faucet ?
just pull straight up,wiggle back and forth,the o-rings are holding it on .
Posted on Jul 15, 2009
Bill Johnson
  • 297 Answers
SOURCE: American Standard Colony Soft gooseneck kitchen faucet leaks base
at the spout near the base is an echeion ring. turn this counterclock wise then pull up ring to expose the neck,pull spout straight up.this echeion cap holds on the spout to the base there are plastic parts inside so be careful when pulling apart.
Posted on Jul 22, 2009
Anonymous
  • 35 Answers
SOURCE: Grohe ladylux plus kitchen faucet leaks from
Yes,it sounds like you have to replace the hose.Follow the braided hose under your sink until you come across a yellow and black fitting . it is comparable to an air hose fitting quick disconnection. once that is pulled from the sink port,unscrew the spray head and pull the ose through the faucet body from above the sink
Posted on Feb 23, 2010
bryan farmer
  • 112 Answers
SOURCE: We are trying to replace a Grohe kitchen pull out
The universal hose will not work on certain model faucets,best bet contact manufacturer and they may provide you a new hose at little or no cost if you tell them you will put a different brand faucet in.
Posted on Jun 12, 2011
Testimonial: "Thanks, that is something I didn't consider. After much wrangling, he did get it loose and re-threaded it. It seems OK for now. Thank you for replyi"
I have a ten year old American Standard Reliant pullout kitchen faucet. It leaks from the body into the cabinet below the deck. I removed the cartridge but was unable to remove the internal body. The...
Hi, Ok I see your problem? LOL The feed lines for the faucet are too close together at the min. you must spread the lines ever so slightly not to over bend, just enough to get the head/bottom of the hose to pull up thru the top. Fun job: level 6 on a scale 1-10. Have at it !
Sep 06, 2013 | American Standard 4205.001.021 Reliant+...
American Standard Kitchen Faucet Low water flow
I had the same issue with an American Standard faucet that I installed new 6 months ago. The diverter can be the issue if you have a sprayer attachment. Try unscrewing the sprayer head from the hose it's attached to. Now run the water full pressure with the hose pointed into the sink, obviously :~). After running the water for about 1 minute, connect the sprayer head back onto the hose, make certain the flat rubber washer and ring gaskets are seated in their grooves properly, and tighten until you have no water leaking from the sprayer head/hose connection. Now try the water through the faucet. If the problem was a temporary diverter issue, your pressure should be fine now. Good luck
Oct 31, 2011 | American Standard Kitchen Faucet 6310 020...
Low water pressure
Remove the spray head and point the hose into the sink drain. Turn the faucet on. If you have good pressure, cal American Standard for a free replacement spray head.
If you still have low water pressure without the spray head, ask them for a new faucet cartridge.
After replacing the faucet cartridge, if you still have low water pressure you will need to ask for a new faucet, possibly free if yours is still under warranty.
Sep 07, 2010 | American Standard Kitchen Faucet 6310 020...
How do I remove the spray hose from the brass connector under the sink?
On the side of the brass there should be a clip or a pin that you can pop off... a knife or screw driver will work to snap it out of there... then the hose will just pull down out of the fitting...
heatman101
Sep 03, 2010 | American Standard Kitchen Faucet 6310 020...
Montuori2947@att.net
check hose to head connection ,i.e. spout.
Apr 14, 2010 | American Standard Kitchen Faucet 6310 020...
American standard kitchen faucet leaking
soak down with WD40 and try again use a bigger wrench they all come off i have not found any that i have not been able remove!
Jul 04, 2009 | American Standard Kitchen Faucet 6310 020...
How to replace sprout seal kit in american standard faucet ?
Jun 05, 2009 | American Standard 4275.550.002 ColonySoft...
Slow and nonexistent water flow.
Start by removing the spray head from the hose. Pull the spray head out and with a channel lock pliers unthread connection between the spray head and hose. BE CAREFUL not to let the hose fall back down into the faucet. With the hose directed down toward the sink test for volume by turning on the faucet. If you get a nice volume the problem is in the spray head. This is usually the case. Put the spray head back on then remove the aerator. It's the screen where the water comes out of the spray head. Clean out the assembly ( 3-4 parts). Reassemble and test.
Good luck, Phil
Dec 11, 2008 | American Standard Bath Faucet Ceramix...
Kitchen spout leaks
Hi buffy9,
Thank you,
Oct 16, 2008 | Plumbing
Plumbing Logo
65 people viewed this question
Top American Standard Plumbing Experts
Thomas F. Schneider
john h
Fahr Quad
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
