You will need to hook up your turntable to a pre-amplifier. You can then hook the pre amp to the video inputs on the back of your MD555. You can purchase a pre amp on ebay for around $15
If you have a pre-amp/power-amp combination then the Bose equalizer connects between the two. If you're using the Bose speakers as front L&R, then the connection is between the front L & R pre-out and the power amp's front L & R pre-in.
I assume you want to use the SU-G91 as a power amplifier to drive your speakers. If your receiver has connections for inserting an equalizer (may be labeled pre-amp output and power amp input), remove the jumpers between the pre-amp and the power amp, then run cables from the pre-amp to the SU-G91 inputs. You can have an equalizer between the receiver and the integrated amplifier. If this is not available, use the recording output (for a tape recorder on older receivers). Note that the volume control on the receiver will be bypassed with this connection.
hi,
Check is there is any pre out for frond left and right channel in your recever. Noramally AV receivers have 5.1 pre out. If so connect the frond left right pre out to the left right input of your behringer a500.
ok
If it is a hd tv, they make a dvi to Hdmi cable, if not that you will have to buy an external tv out card most tv tuner cards have tv out capabilties, Try dazzle
what to remember is pre-amp is before the amplifier then the amplifier to the speakers, go this route, Tuner for radio? from the radio tuner out go to the pre-amp tuner input, then from the pre-amp OUT go to the AMPLIFIER IN, tuner, cd, dvd, tv, any source, if you are using a 2 channel amp and pre-amp this is relatively easy, a little more detailed for multi-channel pre-amps and amps but follow the same path, sound source signal ie. tuner to pre-amp, pre-amp out to amplifier and speaker hookup to amp channels,
