Question about RCA Televison & Video
RCA TV # D52130 turned off for night. Turned on next day, no power light when turned on. Is there a fuse possibly burnt.
    Top Expert:
  • RCA Master
  • 55,370 Answers
Posibly an open fuse or power supply failure
Posted on Dec 11, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: RCA HD52W55 No sound no picture
Have you solve the problem?
Posted on Sep 29, 2007
MeanGene
Willard Wood
  • 5 Answers
SOURCE: Tv wont come on
I have this particular set myself and a similar problem occured.
I replaced Q14101in the power supply and 5amp fuse.
Also replaced Q14101, horizontal output transistor after I tried to isolate a short on the convergence power supply load. Removing the yoke connectors did this, be carful in your troubleshooting. Also the Sanyo STK730-130 IC switching voltage regulator can cause all these problems to start with by failing, it runs off the main power supply. I think I spent less then $50 to repair the thing myself.
Posted on Oct 14, 2007
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: RCA D52130 CHASSIS CTC211A PROBLEM
Do you hear a click when you try to power it up? If no you may have a blown fuse. But if the fuse is blown chances are a short has caused that condition. Check the fuse to see if its blown and let me know and I will try to help you out with it.
Posted on Mar 27, 2008
Anonymous
SOURCE: F35750ST watching one day, turned off, will not come on the next day.
my tv turns off andon
Posted on Jun 23, 2008
caroldon
  • 17130 Answers
SOURCE: Turned TV off at night.
If there was a power outage durring the night it is possible that the power supply or the TV mother board could be effected-- even if there was a thunderstorm.
So in this case you can also check to see if the fuse if blown as a protection or that the SMPS is damaged.
Please remove plug remove rear panel to get access to the circuit.
see the link for tips on SMPS repairs.
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Posted on Jun 16, 2011
Turned TV off at night. Next day went to turn TV on but it was completely dead. What happened?
Jun 16, 2011 | Televison & Video
RCA 26 HDTV LCD Monitor
Probably a burnt fuse, have it serviced.
Feb 21, 2008 | Televison & Video
No power to anything
CK on deflection Board cp150 if it is puffed up on top it is BAD 2200uf16v there is 2 more capacitors also replace 220uf35v.cp111 cp120.
Aug 06, 2009 | RCA D52W23 52" HDTV CRT TV
RCa P52926 52inch
CHECK THE SIMPLE THINGS --MAKE SURE THE PLUG IS STILL PLUGGED IN AC...IF YOU HAD SOME POWER INTERUPTIONS ...MAY HAVE BLOWN THE MAIN FUSE BY THE POWER CORD.DO YOU SEE ANY LED LITES ON THE FRONT OF TV..POWER INDICATOR??? .REMEMBER ,ALWWAY S UNPLUG THE TV IF YOU TAKE THE BACK OFF...TUNICA
Sep 04, 2008 | RCA P52926 52" Rear Projection Television
My 1995 RCA 52
Replace capacitors in power supply,( 4 cap. ) 2.2uf 100V, 39uf 100V, 470uf 25V, Ready!!
Apr 25, 2008 | RCA P52926 52" Rear Projection Television
Tv willnot turn on
Mine just did the same thing on the same day, same tv. we bought ours from Walmart exactly one year ago and after spending time on internet, i have found that alot of us with the same tv have had same problem with no avail from RCA company or walmart. i can't get help from anyone and am ready to scream. Good luck. Others have told me that they have had repair man out and said that it was a malfunction is some type board that he has seen over and over in this tv and he advised to just buy another tv because it was too costly and the problems were going to keep coming with this specific model
Apr 06, 2008 | RCA P52812BL 52" Rear Projection...
RCA D52130
the fuse should be located right near where the power cord plugs into the chassis
Mar 28, 2008 | RCA D52130 52" Rear Projection Television
Mar 27, 2008 | RCA D52130 52" Rear Projection Television
Televison & Video Logo
50 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
