1 gallon (gal) = 3.785411784 kilogram (kg).
20 gallons = 75.708 Kg
Plus the weight of the empty tank (depending on tank construction, glass or part steel etc.)
How many pounds are in a gallon?
A gallon is a measure of volume equal to 128 fluid ounces (fl oz). One fluid ounce of water weighs one ounce (oz). So a gallon of water weighs 128 oz, or 8 pounds.
A gallon of other liquids will vary in weight depending on the density of the liquid.
1 gallon of water weighs 8.33 Lbs and oil is lighter than water so,
1 gallon of Olive Oil weighs 7.6 Lbs or 3.45 Kg on average (depending on temperature).
water weighs 10lb to the gallon ( engilish measurement-calculate amount for us gallon)
so get your self a jug and place it on the scales empty adjust the scales to zero
fill the jug with a measured amount of water (example 1 pint will weigh 1.25lbs
then set the scales to the reading of 1.25lbs
to check the scales accuracy you can add extra water to the jug (say 4 pints ) and the scale should read 5lb
Depends on what you have a gallon of. Water weighs 8.3453 pounds per gallon. Motor oil, being lighter than water, weighs only about 6 pounds per gallon. Other fluids will have varying weights. This is because a gallon is 128 fluid ounces, and a fluid ounce is a measure of volume, not weight.
Hi. A typical soda fountain-style ice cream scoop--a #8foodportioning scoop--holds 1/2 cup of ice cream. One gallon is equal to 16 cups, so there are 32 scoops of ice cream in a one-gallon container. Each scoop should weigh 4 ounces. A strong handed scooper can put an ice cream shop into bankruptcy so ALWAYS weigh each and every scoop. With soft serve, one gallon of mix makes 36 - 4 ounce cones. Once again weighting the cones is key. The hot dog vs hamburg ? depends totally on the sizes, the toppings and the type of roll used. Experiment there but start out with hot dogs to keep it simple. Regarding chips and fries, once again chips are simple with little waste, cold fries often go in the trash. Good luck. J.
