If your Xtreme Power US 2200W jackhammer is not working and not making any sound, there are a few troubleshooting steps you can try before determining if it is beyond repair:
Check the power source: Ensure that the jackhammer is properly connected to a power outlet and that the outlet is functioning correctly. You can test the outlet with another device to confirm if it's supplying power.
Inspect the power cord: Examine the power cord for any visible signs of damage, such as cuts, fraying, or exposed wires. If you notice any issues, it's important to replace the power cord or have it repaired by a professional.
Verify the power switch: Make sure the power switch on the jackhammer is in the "On" position. Sometimes, the switch may get stuck or be in an intermediate position, preventing the tool from turning on.
Check the circuit breaker: If the jackhammer is plugged into an electrical circuit with a circuit breaker, verify that the breaker hasn't tripped. If it has, reset the breaker and try again.
Examine the carbon brushes: Jackhammers typically have carbon brushes that make contact with the motor to enable operation. Over time, these brushes can wear out and require replacement. Open the jackhammer and inspect the carbon brushes for wear or damage. If they appear worn down or damaged, they may need to be replaced.
Seek professional assistance: If none of the above steps resolve the issue, it's recommended to seek assistance from a qualified technician or contact Xtreme
Hi Emani, to complete hard resetting of your Xtreme tablet, you have to hold the power button on / off along with volume button up / down simultaneously. Then only you get a menu in which you have to select the option for hard reset. Then, your tablet will complete get hard reset and go back to how you bought it.
check with the bank what browser version they require... if you have the correct version then make sure you have the correct Java plug in installed... also you may try to include other banking sites to your trusted sites.
hold the reset button for 10 seconds then let it sit till the lights stop flashing. then you'll be able to log into the router w/ the default user/password which I believe is admin/password. the ip should be reset to 192.168.1.1 so type http://192.168.1.1 in your browser to log in.
