SOURCE: snow thrower won't throw snow
the problem could be the snow is to heavy for the motor to keep up, if thats the case you may need to upgrade to a more powerful model or try not to overload it. take it a little slower so the motor can keep up. but try tightening the belt. with your pointer finger push down on the belt it should have about a half inch give, if it moves more than that its too loose and probably slipping under load
SOURCE: craftsman 8hp snowblower starts but will not stay
Your snowblower carburator is gummed up. Go to an auto parts store and get a can of a carb. cleaner called seafoam. Follow the directions as far as how much to put into the snowblower gas tank. Run it for a few minutes and it will clear up. Regards, Joe
PS Please rate my answer. Thank you.
SOURCE: CRAFTSMAN SNOW THROWER DRIVE WHEELS WILL NOT MOVE
well if it is a walk behind style it could be the drive is out of adjustment, also craftsman were famous for the cable mounts bending and that will throw them out of adjustment. follow the traction drive linkage down to the base of the blowe and there should be an adjustment, or it will be under the belt gaurd or even on the handle on some.
SOURCE: I have a Montgomery Ward Snow Thrower Model 495A.
I have an older Montgomery Ward Snow Thrower model No. TM0-35286A and I'm having a hard time finding parts for it. The tiller just stopped working so I'm thinking the worm-gear is shot, but I can't even find the part on-line...Can you help?
