Question about LG Washing Machines
Do you have Drawer for lg refrigerator LMX25984
Lg. LMX25984 drawer
    Top Expert:
  • LG Master
  • 55,370 Answers
Fixya does not sell LG parts.
Posted on Dec 10, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: LG Tromm - soap drawer is stuck and will not open
This is caused by the "Fabric Softer" removable tray inside the drawer getting stuck in the top of the drawer cabinet.
Solution:
1. Unplug machine
2. Remove four sheet metal screws and plastic plates from top of back of machine that hold the "lid" on (perhaps yours is different and only has two screws, but that's your world :) )
3. With the palm of either hand hit the both sides of the lid of the machine at about a 45 degree angle towards the back of the machine until the lid slides back about 4 inches
4. Gently remove lid (will lift off easily if you've freed it correctly)
5. On left you'll see a white box which is the cabinet for the drawer. Carefull pull the black wire from it's retainers
6. Lift up the three clips on the right side of the cabinet that hold it together
7. In the back of the cabinet, grab ahold of the plastic piece that doesn't have a hose attached (unless yours does, in which case figure it out yourself :) ) and gently pull up until you can see the cabinet coming apart in the back.
8. When you have enough clearence push a screwdriver through the opening you've created while lifting on the back of the cabinet apart, and PRESTO! The drawer will pop out.
This will happen everytime from now on if you do not remove the the "fabric softner" tray from the drawer. It is a design flaw that will happen to all models eventually. If you must have that little tray, then find a solution that works and post a follow up here (I imagine it will involve a bench grinder :) )
HAPPY WASHING AND BUY AMERICAN!!!
Posted on Nov 26, 2008
Anonymous
SOURCE: lg dvd drawer opens by itself and wont stay closed
I tried the solution documented at
http://www.ifndef.altervista.org/index_eng.html
3:rd Loader repairing
Posted on Jan 28, 2009
Anonymous
SOURCE: front loader LG washer drawer for detergent is stuck won't open
Remove the top of the washer by removing the 2 retaining screws (phillips head) from the back of the unit & sliding the washer top back about 2" & pulling up. You will see a white detergent dispenser box with several hoses coming off the back in the left front of the unit (this box contains the detergent drawer). The lid to this box is held on by 8 pressure snap clips. You only need to release the 4 snap clips (3 large, 1 small at the rear) on the right side of the box (nearest the washer drum). Pull up on the right side of the lid while pulling out on the detergent drawer. It should come out normally. Do not reassemble until you read below, then reverse the steps to put the washer back together.
The problem will be the "softener" lid (blue). It will not be sitting down in the drawer assembly & will catch on the lid of the white detergent dispenser box. Simply remove the blue lid to avoid future jambs. It only serves to identify the fabric softener recepticle & it keeps fabric softener from splashing around when water enters the system. You may need to remove the entire detergent drawer periodically to clean (push down on the blue thumb indent inside the drawer to release it from the housing).
Hope this keeps you from drilling through the lid & ruining a $23 part, like I did.
Posted on Jun 16, 2009
Anonymous
  • 161 Answers
SOURCE: HOW TO CLEAN SOAP DISPENSER DRAWER ON LG WASHER
On the very back top of the drawer is a lock lever that you depress to relase the drawer. Push it down and pull drawer out. Clean and replace.
Posted on Jan 27, 2010
Chris Jowsey
  • 208 Answers
SOURCE: LG RH1757 (80 GB) DVD Recorder / HDD Recorder
Could be a timing issue with the tray mechanism - possible that somebody has given the tray "a shove" to make it close instead of using the open/close button and has put the timing out.or a worn tray loading belt
Posted on Mar 18, 2010
Samsung RFG298 Freezer Drawer is not sliding out all the way.
Look for an obstruction on the slide-rails, or ice building up on one of them... Maybe this will help, LG and Samsung use a lot of the same designs. (garbage)
LG Refrigerator Freezer Replace Lower Drawer Gear 4403JA3005A
Dec 11, 2016 | Samsung Refrigerators
LG french door no cooling
Pull away from the wall and remove the panel near floor to expose the compressor. Feel the top of the compressor to see if cool, warm or too hot to keep your hand there. Tell me your findings. Is compressor clicking? Is the model number LMX25984 above your post correct?
Appliance 911 Sea Breeze
Aug 10, 2015 | LG LMX25984
DROWER PART NO-3390JA1083 refregirator LG serial
Hello, I leave in Israel and I have LG refrigirator and the drawer is broken. Can you please help me find where I can get a new drawer:
Regards,
Irit Gold
Feb 28, 2011 | LG Refrigerators
Freezing in left crisper drawer.
If you have had a DOE upgrade the fix is availiable from LG
Here is the service buliten # CREF20090877.
Contact LG @ 1 800 243-0000 for repair.
In the mean time remove crisper dware and look on the back wall of the ref. you will see a dime sized hole on the center tower. Cover the hole with tape and reinstall crisper.
Jan 19, 2010 | LG LFX25960 Bottom Freezer French Door...
LG LRFD25850 French Door Fridge set at 37-40 c keeps freezing produce at back or in large bottom drawer
Pull the drawers put and cover the cold air vent (small hole at back wall) with tape ...problem solved!
Jan 08, 2010 | LG LRFD25850 French Door Refrigerator
Water Leaking From Under LG LRFD21855 Refrigerator
yep, it looks like a frozen drain pipe. to solve it , defrost your frig for 24 hours. if that doesn't help, see the following page for details how to fix it. http://www.schneordesign.com/Avi/LG/LG819_fix.htm good luck Avi
Sep 16, 2009 | LG LRBC22544 Bottom Freezer Refrigerator
Bottom freezer door/drawer won't close all the way on one side.
Remove all the food from the freezer and then the drawer from the cabinet. Now using a silicone based lubricant, lube the tracks up real well. Be sure to clean the tracks first if gunked up. Make sure nothing small fell out of the basket over time and is laying on the floor in the rear of the freezer section. Once done, you should be fine.
Eric Campion
Feb 21, 2009 | LG LRFD25850 French Door Refrigerator
Ice maker tray
There is a fix for this problem.  Call a qualified LG tech to order the updated metal bar for this icemaker.
Feb 02, 2008 | LG LFC25760ST 25 Cu. Ft. Panorama French...
Washing Machines Logo
44 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
