Whenever i get started with my pc . i am getting this notification
error loading C:\PROGRA~1\MYWEB~\bar\3.bin\M3PLUGIN.DLL
so i request you to solve this problem.
Go to Start - Run and type MSCONFIG then press Enter and choose either Services or Startup to try to identify which application may be loading m3plugin.dll and uncheck it
Is every program running fine? It is a registry file - in other word a file that is the basis for all programs. If every program is running fine, you can delete by start>run>and type regedit or if in Vista start>and type regedit. Use the path in the error (C:\PROGRA~1\MYWEBS~1\bar\2.bin\M3PLUGIN.DLL) to find the file and delete it.
I followed these steps and haven't had any issues since:
1. Go to START menu 2. Select RUN 3. Type MSCONFIG and click OK (or press ENTER) This will bring up your System Configuration Utility window. 4. Select the STARTUP tab. 5. Find M3PLUGIN, untick it, select APPLY and then OK This will bring a popup dialogue box stating the following:
"You must restart your computer for some of the changes made by System Configuration to take effect."
6. Select RESTART.
When your computer restarts, you should no longer receive that message.
