SOURCE: HP PhotoSmart 7760 InkJet Cartridges Stuck to the RIGHT.
What do you mean by foots sticking the cartridges, is it part of the printer, or the cartridge
SOURCE: my hp photosmart 2575 says
open the front cover the cartriges will come in the centre position where you can remove the cartridges check which cartridge is on your right side remove and clean the brown dotted circuit on both the printer and cartridge with the tissue paper .insert it back in the proper position and then check if the same problem then remove and replace the cartride printer will work properly.thanks
SOURCE: HP PHOTOSMART C4280 PRINTER WONT READ INK CARTRIDGE.
The cartridge is not seated properly and/or the contacts are dirty. Use a cotton swab with rubbing alcohol and gently clean both the copper contacts on the cartridge and inside the cartridge socket. Allow several minutes to dry and then try again.
SOURCE: Printer Reset instructions for HP 564 inkjet cartridge.
Dear, this is basically an auto generated message based on system registery keys, if you want to bypass the message, then there are two ways.
1. put another cartridge in the printer and try to print, after than install the previous (original) cateridge, this will doge the printer as a new cateridge, you problem will be removed. but if you don't have another similar cateridge at hand then follow the step 2 given below.
2. Uninstall the driver, unplug the printer, restart the system and reinstall the printer dirver again, your problem will be removed.
Best regards.
SOURCE: printer keep restarting. c6180 hp photosmart
Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This also fixed the ink system failures the printer was having. A similar fix may apply to other printers produced by HP around this time.
