ZEBRA pRinTeR inStaLlAtIoN sUpPoRt nUmBeR #@ {877.769.0969} USA ZEBRA pRinTeR inStaLlAtIoN sUpPoRt nUmBeR {877.769.0969} to resolve all PHone ducts. ZEBRA pRinTeR inStaLlAtIoN sUpPoRt nUmBeR is an American multinational company which was founded by Michael using its company headquarters in Round Rock, United States of America ZEBRA pRinTeR inStaLlAtIoN sUpPoRt nUmBeR which is available at 24/7 *365 days.
SOURCE: How to configure the Zebra S500 using a USB to Parallel adapter?
The Zebra Stripe S500 has a RS-232 SERIAL interface using a DB-25 connector . You'll need a USB to SERIAL converter, not parallel. Be sure that the baud rate and data/stop bits are set the same on the printer and interface converter. Generally speaking, use the fastest setting possible (19200 baud) unless you encounter problems.
SOURCE: Zebra printers & MS Word
HI Les1810,
You should be printing faster with Zebra fonts.
Which driver are you using? Version?
I strongly recommend the Zebra Designer V1.3.08, available at Zebra.com
To isolate the problem, capture the output to a file.
Define a local port as C:\output.txt and set that as the port in driver properties.
Now print your document. The printer commands will be in C:\output.txt.
Send c:\output.txt directly to your printer.
For LPT1, use the DOS copy command to send the file. (Copy C:\output.txt LPT1)
For serial connections, use Hyperterm to send the file.
For network connections, use ftp.
No easy USB method is readily available.
Does this print faster than printing the original document from Word through the driver?
If yes, then update your driver.
If no, debug your communication to the printer (LPT1, serial, network, etc.)
SOURCE: Zebra SM4 label printer to change ZPL to EPL
You will need to change the firmware on this printer in order to be able to change the language. I don't believe this printer will allow you to change the language using the advanced options in the menu unless they have recently changed this.
Here is a link to the manual where it tells you where you can download the firmware for the printer and how to install it. It is pretty easy but if you have any problems, please get back to me and i will point you in the right direction.
SOURCE: Zebra LP 2844 printer will not print anything but the test page
possibly not a real LP2844 but an LP2543, a printer mass produced for and used by UPS. refurbishers change the label and sell as LP2844 because they are almost identical.
if it has an AC-AC adapter, it is an LP2543. LP2844 uses a AC-DC adapter, and all LP2844's have USB ports.
SOURCE: Problem with my Zebra LP2824 printer
You have to calibrate the printer to solve this problem
Check following to solve this problem
1)Press the feed button and hold it for 1-2 seconds switching printer on.It will calibrate the labels.
2)Install Zebra Designer driver from CD.After installing Zebra designer Add printer Zebra Designer LP2824.After installing driver right Click the printer Zebra Designer LP2824 and go to printing preferences then select advanced option and calibrate printer.It will calibrate printer
3)Check the label size is properly set in printer or not.Label width and label height in printer settings should be same as label which you are using .
