Question about RCA Audio Players & Recorders
THE REMOTE DON'T WANT TO WORK EVEN WITH NEW BATTERIES. I HAD TO ORDER A SECOND REMOTE AND NOW BOTH OF THEM DON'T EVEN WORK OR GIVE SIGNAL and the play button on the system don't start a dvd
I HAVE A RCA RTB10323LW 200W BLUERAY/DVD WIFI HOME THEATER
6ya staff
SOURCE:
Anonymous
SOURCE: Oritron DAV 3102 home theater system
I found a website for the remote you need. I need one too. Go to remotes.com and put your model number of DAV 3102 in the space. It will show you the original remote and a replacemet you can use. Kind of expensive but worth it to me.
Posted on Jun 25, 2008
Anonymous
SOURCE: rca rt2770 home theater universal remote code
hehehe i just found it mebbe i will tell u mebbe i will jk this is it either - 0790,1913,31023,31609,31254 mebbe one of those will help. the first one worked for mine. i take it u know how to program the remote
Posted on Jul 02, 2008
Anonymous
SOURCE: No Sound In Home Theater with Dish HDTV DVR Dual Mode Remote Connection
I have a high definition Polaroid tv which I bought in 2007. I have it connected to Dish tv. It worked fine at first. Now when I use the Dish tv remote, the television won't power up. The red light, which appears when the television is off turns blue when I attempt to turn the tv on, but the screen stays black. Why won't the television come on anymore?
Posted on Nov 02, 2008
Anonymous
SOURCE: Sony DVD Home Theater System remote control code
I have the same system and one of my dogs got to the remote. I have a philips PMDVR8/PDVR8 universal remote. I was able to get the dav-hdx265 to turn on/off and do volume up and down by using code 0200. I have not been able to get the DVD functionality to work yet, but I will post if I do.
Posted on Dec 14, 2008
Anonymous
SOURCE: need to program 311w U. remote to RTD215 home theatre
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr311-manual.zip&area=other
Posted on May 03, 2009
I bought a second hand VD player with remote, player works great but remote does not work at all, even with new batteries
Buttons on the remote control should work individually. If it is universal remote control [not the original one with the projector], you should have to set it up with its set-up codes. For more details, you have to download the manual to the remote control you have, if it is a universal one. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Mar 24, 2014 | Televison & Video
Rc helicopter not getting signal from remote
I think you have damaged the copters electronics when you crashed it.
Jun 27, 2017 | Toys
1996 Dodge Caravan 3.8 V6 ...the turn signal don't work. It used to work on some warm days. Sometimes I had to wiggle a little bit the relay and it works. Now, its just don't do anything. Fuses...
you may have a second flasher unit , one for the emergency flashers and one foe the turn signals, some Caravans do . if yours doesn't happen to be one of them, you have a short in the switch itself, and will need to remove the steering wheel to replace it,, be careful, and follow the instructions for air bag safety when working with anything near the air bag,, remove the neg battery terminal first ,, then the positive,, and wait 10 minutes before doing anything else, this gives the system to discharge . when your done, hook up the battery in the reverse order
Sep 29, 2011 | 1996 Dodge Caravan
Our Samsung remote control ARH-428 will not work. We have changed batteries however we can not make it operate our air-conditioner
If even with new batteries not working means transmission signal problem. May be with remote or receiving signal problem with indoor. Check your remote with camera mobile and press on/off switch. If it's ultra light flashes, it's o.k. Then repair receiving signal in PCB.If no ultra light in remote, replace remote.
Dec 27, 2010 | Heating & Cooling
I have the gray Comcast DVR remote control-it is so unresponsive!
I called Comcast about this today and they had me turn off the TV, unplug the DVR, unplug the coaxle cable, wait a second, rescrew in the coaxle cable, replug in the DVR. It worked! The DVR is snappy like it used to be. Such a relief because it was soooo annoying. Good luck.
Feb 28, 2010 | Televison & Video
How to program the orginal remote camry key2003
I found this on the internet try it it MAY work.
Start with the key out of the ignition. Open the driver door (all other doors are closed). Driver door is unlocked (other doors don’t matter).
Perform these steps within 5 seconds
Insert the key into the ignition (don’t turn it)
Perform these steps within 40 seconds
Close, then open the drivers door.
Insert the key into the ignition (don’t turn it) and pull it out.
Insert the key into the ignition and leave in the ignition.
Close the drivers door
Turn the ignition to ON (as far as you can go without cranking the engine), then back to off .
Remove the key from the ignition.
Within 3 seconds, the power door locks should lock then unlock automatically indicating successful entry into programming mode. Return to step 1 if the locks do not cycle at this point.
Press the lock and unlock buttons on the transmitter simultaneously for 1.5 seconds
Immediately after letting go of the lock and unlock buttons, press the lock button by itself and hold for 2 seconds. Within 3 seconds, the door locks should lock then unlock once indicating successful programming. If the door locks cycle twice, repeat steps 6a and 6b as the remote was not accepted.
Open drivers door
Dec 18, 2009 | 2003 Toyota Camry
Replaced battery in remote even though old battery still had 3 volts,tried to initialze per instructions and still won't unlock door.get no chime when programming, just run out of time.2001 chevy impala
• Resynchronization may be necessary due to the security method used by the remote keyless entry system. Resynchronization may be necessary due to the security method used by the remote keyless entry system.
The transmitter does not send the same signal twice to the remote control door lock receiver (RCDLR). • The RCDLR will not respond to a signal that has been sent previously. This prevents anyone from recording and playing back the signal from the transmitter. • Resynchronization may be necessary under the following conditions: - The battery in the transmitter is very weak. - The battery in the transmitter was replaced. - The battery in the vehicle has been in a low or no charge condition for an extended period of time. • In order to resynchronize the transmitter with the RCDLR, perform the following steps: 1. Stand within 1.5 m (5 ft) from the vehicle. 2. Simultaneously press and hold the LOCK and UNLOCK buttons on the transmitter for 7 seconds
Jun 25, 2009 | Chevrolet Impala Cars & Trucks
Remote controls for factory alarm system are not working.
Resynchronization may be necessary due to the security method used by the remote keyless entry system. The transmitter does not send the same signal twice to the passenger door module (PDM). • The PDM will not respond to a signal that has been sent previously. This prevents anyone from recording and playing back the signal from the transmitter. • The panic button should still operate normally when the system is out of synchronization. • Resynchronization may be necessary under the following conditions: - The battery in the transmitter is very weak. - The battery in the transmitter was replaced. - The battery in the vehicle has been in a low or no charge condition for an extended period of time. • In order to resynchronize the transmitter with the PDM, perform the following steps: 1. Stand within 1.5 meters (5 ft) from the vehicle. 2. Simultaneously press and hold the LOCK and UNLOCK buttons on the transmitter for 7 seconds. The door locks should cycle in order to confirm resynchronization.
Apr 30, 2009 | 2003 GMC Yukon XL
27 people viewed this question
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
