Thanks for photo link. Not a smart meter.
Just ordinary water heater gas control valve, with small circuit board to support error codes:
Copy following link for handy resources:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intelliventhttp://www.thetankatwaterheaterrescue.com/forums/forum3/http://waterheatertimer.org/How-to-replace-Honeywell-gas-control-valve.htmlHow the newer gas control valves are different: Old water heater had thermocouple which supplies very tiny current to gas control valve. When pilot light blows out, the thermocouple no longer sends tiny current and gas control valve shuts off gas to heater.
New gas water heaters have thermopile (just like modern furnaces and stoves), which is basically several thermocouples bunched together. So thermopile sends more current to gas control valve, and supplies enough current to power small circuit board. The circuit board records error events and issues simple error codes. If pilot blows out, then thermopile no longer sends current and gas control valve shuts off gas to heater.
Moreover, the new gas control valve can be repaired and replaced without removing from tank. So tank does not have to be drained... saving time and repair cost.
Gene
If you need further help, I’m available over the phone at
https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
