Hi James Kohler, to connect the EQ SH-8029 to the Kenwood KR-710, you must have two cables from 2 RCA to 2 RCA
One connects it to the EQ Line In (Line In) and on the other hand you connect it to the REC output of Tape1 in the Kenwood, the other cable goes from the Line Out of the EQ to the entrance Tape1 PLAY at Kenwood
In order to hear the equalized sound, you must select the Source, example; Radio CD, Phono and you must enable Tape 1
If you had used Tape 1 connections, you can use Tape 2 and if you have used both of Tape, you can do what you indicated first and what was in Tape 1 connect it to the Tape entrance, which brings the EQ
I hope you can connect it
Greetings Franco Dosil
Hola James Kohler, para conectar el EQ SH-8029 al Kenwood KR-710, deberas contar con dos cables de 2 RCA a 2 RCA
Uno lo coenctas en la Entrada de Linea del EQ(Line In) y por el otro lado lo conectas a la salida de REC de Tape1 en el Kenwood, el otro cable va desde la salida de Linea (Line Out) del EQ hasta la entrada PLAY de Tape1 en el Kenwood
Para poder escuchar el sonido ecualizado, deberas seleccionar la Fuente, ejemplo ; Radio CD, Phono y debes habilitar Tape 1
Si tubieras utilizadas las conexiones de Tape 1, puedes usar Tape 2 y si tienes utilizadas las dos de Tape, puedes hacer lo que te indique primero y lo que estaba en Tape 1 lo conectas en la entrada de Tape, que trae el EQ
Espero lo puedas conectar
Saludos Franco Dosil
https://www.manualslib.com/manual/287007/Kenwood-Kr-710.html
Thank you very much Mr Dosil. This was my first use of this great site. Will be many more connections I'm sure. I would have given you the highest score I could have. Fixed within 3 min. Thanks again!!!
Thank you very much James Kohler for your comments, that is the idea, to give the best possible solution
Enjoy your audio equipment
Best regards, Franco Dosil
SOURCE: connection between CD, EQ, SP technics
Each unit (the EQ and the Processor) should have left/right in/out rca jacks as well as L/R tape in/outs. The EQ or processor use the receiver's tape loop and then provide a tape loop to replace the one they've used on the receiver.
You plug the first unit (let's say the Sound Processor into your receiver/amp as if it were a tape deck (Processor's outs connect to reciever's tape ins (play) while the Processor's ins connect to the receiver's tape outs (record).
Then you chain the EQ off the Processor in the same way (EQ outs connect to Processor's tape ins (play) and EQ ins connect to the Processor's tape outs (record).
Last you connect the tape deck to the EQ as follows. Tape deck outs connect to EQ's tape ins (play) and the tape deck ins connect to the EQ's outs (record).
This will put both the Sound Processor and the EQ in the receiver's tape loop. In order to have all the receiver's source signals routed through them you may have to engage a Tape Monitor switch or button somwhere on your amp which will route the tape loop to your speakers.
SOURCE: Technics SH-8017 Equalizer
use youe tape out signal into the eq's main input and the eq'sout back into the record side of ur tape source.
SOURCE: Optimus 7 band equalizer model # 12-1969
I need to know what the wire are coming out the back of the optimus seven band stereo frequency equalizer/booster
SOURCE: I have a 1986 vintage Technics component system
Since you have all the model info on hand, go to the manufacturers web site, look for the support page. if it is an older system, you'll want to look under older products, legacy or OLDER equipment. If that does not work, then try google. If all else fails, just remember>>> the Equalizer is the last component that plugs into the AMP's INPUT.
SOURCE: How do I hook up technics equalizer sh-ge70
This is boilerplate I wrote a long time ago for general eq or sound processors. Without know to what you are connecting, well, read on...
Be advised that the engagement of any device in a Tape Monitor loop will effectively tie the receiver down to stereo-only analog sound reproduction. I'll explain.
The connections themselves are fairly simple but it pays to understand what happens in the loop.
In general, any Line-Level external processor (EQ, dynamic range expander, etc) will go into a Tape Monitor loop on a receiver. A Tape Monitor, when engaged, sends the stereo analog signal Out to the Processor, massages it and returns it to the receiver via the Tape Monitor IN connectors to be passed on to the receiver's internal processes (volume, tone, whatever).
Old school analog stereo-only receivers consistently work this way. Newer digital and audio/video receivers introduce a couple of problems: 1) digital sound processing to simulate a variety of soundfields; 2) multiple output channels, either discrete or digitally-generated.
The latter requires that whatever signal is being processed experiences a maximum of one analog-digital-analog conversion.
EVERYTHING analog coming into the modern digital receiver is automatically converted to a digital signal for internal processing unless you choose a STEREO-only or STEREO-Direct setting. Consequently, no further external analog-digital conversions would be allowed if, say, a Tape Monitor circuit was activated, and a possible feedback loop could otherwise be created in a digital-sourced selection (output to its own input), so the unit is wired to treat the Tape Mon as the first analog step in the process and defeats any pure digital sources.
In a multichannel unit, what would happen to the other channels if you sent ONLY the Front Left & Right out for processing? That logical problem also plays into the decision to defeat digital sources if the Tape Mon is activated. I don't totally agree with the engineers but that's the way it is. Nature of the digital beast.
Okay, back to the hook-up: Receiver Tape- or VCR Out to the External Processor (EQ, whatever) Preamp-, Amp-, Tape- or Rec-In; Receiver Tape- or VCR In from the External Processor (EQ, whatever) Preamp-, Amp-, Tape- or Rec-Out.
If you actually want to use an analog recording deck you could place it within the typical Equalizer's own Tape Monitor loop(s). Many have two to facilitate equalized dubbing between decks.
Testimonial: "Thanks for the info I'll make sure I hooked it up correctly."
