KX-W6050: How to disconnect the cable of the tape deck(s) from the motherboard? Do I need a special extraction tool?
6ya staff
SOURCE:
Anonymous
  • 104 Answers
SOURCE: taperecorder no "foreward" or "backward" run ( and a "start" problem
It will be one of the drive belts , its better to get a repair shop to replace both belts , i have tried replacing belts myself and they are fiddly and time consuming , if you keep playing it the way it is you will damage the motors that turn the belts
Posted on May 23, 2009
Anonymous
  • 1985 Answers
SOURCE: Bought a special tool to extract the fuel line
you are just have to spray in the connector with WD40 or something like that and keep trying and turning the tool to different positions to make sure you hit the locks.
Posted on Dec 19, 2009
Billy Rennie
  • 91 Answers
SOURCE: I need to replace the front and rear oxygen
you can get a special socket but a normal spanner will suffice
Posted on Dec 31, 2009
leedavidian
Auto Repair Help
  • 1420 Answers
SOURCE: How do i remove the
Welcome to FixYa.com Do you have the premium IV or V system ? If so, below is the location of holes to remove radio. Regards, Lee d4f9f93.pnga8e4424.png3928517.png
Posted on Aug 20, 2010
Testimonial: "cheers very helpful. nice one mate"
Bryan H
  • 42 Answers
SOURCE: Do I need a special
The whole basket isn't all that great to take off....but if you are just changing the clutch plates, you won't need to remove the basket. There will be an outside pressure plate holding them all in there, usually 5 bolts hold that down (those 5 bolts also have the clutch springs under them) Pull that off, and inside there will be the part that your clutch pushrod moves to release tension on the plates (sorry forgot the name of it right now) make sure that when that comes off, that you don't lose the ball bearing behind it. Goodluck.
Posted on Feb 16, 2011
I took my Pioneer SX-450 Receiver and Pioneer CT-1040W Tape Deck apart to move it. Put it back together. Now can't get a tape to play.
After putting a known good tape in the deck, push play, if the tape doesn't move, try rewind and FF. If nothing happens, the deck has a problem. I assume this is a cassette deck. If so, I always try the thrift stores for a new(used) one. There are good bargains there.
Dec 22, 2016 | Pioneer Audio Players & Recorders
Videotape dubbing deck dead
1. Check to see if a tape is jammed inside (see 284 Extract a Jammed Videotape).
2. Try changing the video input and/or output source. Many VCRs have two ways to receive and send a video signal (coaxial and video direct). If that works, try changing the cable for the other method to see whether you need a new cable.
3. Clean tape heads (see How to Clean VCR Heads).
4. Open VCR and inspect any belts that are accessible (see 284 Extract a Jammed Videotape). A drive belt may be broken or loose.
If tapes are getting stuck / enmeshed inside the machine, itis 90% probability) a mechanical problem. Change the Belts, clean all rollers, idlers, and braking pads.
I would suggest that you also replace the Capstan Pinch Roller.
Goodluck..
Feb 17, 2008 | Rio Go Video DDV9556 Dual Deck VCR
Kenwood kx-w6050 dual cassette deck. play, rewind n forward got problems? Whats seem the problem to be?
It needs servicing by a Technician- often times say it only needs belt but you can replace belts and still have the same problem. The dried lub has to be removed and new fresh non- degrading grease needs to go in and then it will work. Dual cassette decks are usually not worth the $200 it will take to work on two mechanisms. You might find a $10/Hr technician but I doubt it.
Aug 07, 2015 | Kenwood Audio Players & Recorders
How to tape from one deck to another?
Press the Dubbing A to B button. Put your blank tape in deck B. Press REC/PAUSE on deck B. Press Play on deck A
May 21, 2014 | Technics RS-TR272 Single Cassette Deck
Difference between a Yamaha KX 580 and a KX 580 SE cassette deck
Managed to find this blurb...
"The KX - 580SE is a refined model of the popular KX - 580, three time winner of ''What Hi Fi? Best Cassette Deck Award''. The KX - 580SE is a special edition which is UK specified. This cassette deck features CD to tape synchronized record start, timer record / play, new audiophile components in both the dolby and audio output stages, two - motor stable transport, Dolby HX pro dynamic bias servo, auto tape tuning and improved power supply."
Feb 11, 2014 | Audio Players & Recorders
Kenwood KX-79 CW dual cassette hook up?
Just connect the deck via tape 1 the out of the deck going to the in of the amp. While the out of the amp goes to the in of the deck.
The tape deck itself will automatically choose the player that plays the cassette. One will play the other will be on pause (if you press both play buttons) till the tape stops then the other will play. For recording from tape to tape one deck will be the copy and the other the copier. There should be a dubbing button which you press to record tape to tape. Some models have a high speed dub also. For recording from the amp unless both decks have record buttons you will only be able to record with one deck. Make certain the dub button is not set.
Dec 25, 2013 | Kenwood Audio Players & Recorders
Looking for schematic for Kenwood KX-55 stereo cassette tape deck
These dual cassette deck are rarely worth he effort to put repair time into. I checked Hi Fi Engine and they did not have anything. Is it worth a $100 repair bill? if not then look for a good solid single deck.
Mar 31, 2013 | Audio Players & Recorders
Technics M14 cassette deck has hum. Bought used and had hum but I got it to go away by switching the tape select dial to metal,etc. but hum came back later. I'm thinking ground or a wire to that switch. ...
If the hum is audible without monitoring a tape playback it has nothing to do with the oxide formulation or any aspect of the media.
Determine the conditions present whenever the hum is present:
Player just turned ON?
Tape deck Playing or Paused?
Tape deck Recording or Paused?
"Tape" selected at the receiver?
Any source selected?
What switch are you referring to? You could have a floating ground or shield through a Tape Monitor or other control. Audio cables between the Deck and the receiver could be faulty or require reseating with a twisting motiuon to remove oxide build-up.
Hum can enter any unshielded cable running near any motor, magnetic field or some light sources. Sometimes simply reversing the polarity of an AC power cord will cure it.
Feb 02, 2011 | Yamaha KX-393 Cassette Deck Dual Cassette...
How do i get the tape deck out to install a cd player?
Hope this helps! Please don't forget to rate!
Example of the special radio removal tool
Exploded view of the radio mounting and wire connections. Note the rear support and the bracket that it attaches to
  1. Disconnect the negative battery cable.
  2. On 1991-92 models, remove the finish panel from around the radio assembly.
To remove the radio, insert the removal tool prongs into the release clip access holes (arrows)
Push in approximately 1 inch (25.4mm) to release the retainer clips, then pull straight out to remove
3. Insert the radio removal tool T87P-19061-A or equivalent, into the radio face.
4.Press in 1 inch (25.4mm) to release the retaining clips, then using the tool as handles, pull the radio out of the instrument panel.
Disconnect the antenna ...
... and the electrical wire harness plugs from the back of the radio
  1. Disconnect the antenna and wiring connectors from the radio.
To install:
  1. Connect the wiring and slide the radio into the instrument panel. Ensure that the rear mounting bracket is engaged on the mounting track in the panel.
  2. If removed, install the finish panel
  3. Connect the battery cable.
  4. Check the operation of the radio.
Jan 10, 2010 | 1992 Ford Explorer
Taperecorder no "foreward" or "backward" run ( and a "start" problem
May 17, 2009 | Kenwood VR-6050 Receiver
44 people viewed this question
Ekse
 Grubhead
Grubhead
