Question about Hilti Drills
How to remove armature from a hilti TE 17 - Hilti Drills
Anonymous
SOURCE:
Anonymous
  • 152 Answers
SOURCE: hilti te 10 switch problem
You may research your area for a Hilti service center / dealer or order your part directly from
www.hilti.com
or call (866) 445-8827
Good luck
Aduz
Posted on Mar 15, 2009
Anonymous
SOURCE: i need wiring schematics for hilti te 905 avr
Wiring schematics can be found by Hilti 1-800 number but they probally will not help you. The 905 is programed to shut down for service every 40 hours plus 10 warning. Then in my case I am stuck with a 200 dollar bill to send the tool from Winnipeg to Montreal for reprograming. Its a joke in my situation and its on me from Hilti, what a good name but what a scam.
Posted on Jun 09, 2009
Wysepaul
  • 61 Answers
SOURCE: parts for my hilti te 76
If you send me an email i will send you the parts diagram. parts are available from me but I am in Gibraltar. but I can give you a quote if you like.
paul@wysehire.gi
www.wysehire.gi
Posted on Oct 11, 2009
thinglenn40
  • 123 Answers
SOURCE: Hilti TE 17 Rotary Hammer repair switch fix
If you are talking about the wire going from the switch to the stator it difficult to get to. You have to remove the motor end cap, cooling fan and handle holding the switch. this will get you to the brush holders. These can be brittle so you need to be carefull. Turn the motor over and tap the end of the armature on concrete checking the brush holders every couple of taps to see if they are coming out of the motor housing. after they clear they will just come out. If you havn't done so already remove the wires going to the brush holders. Your stator will simply slide out after your brush holder comes out. This will give you access to the wires to repair.
Hope this helps.
Posted on Oct 29, 2009
Testimonial: "worked well for me"
dino4061
SOURCE: NEED PARTS FOR HILTI TE 17
hi i have a 30 year old hilti te17, yes i know but its great but i need the bit holder ( chuck i think its called, the thing that hold the drill bit in for this hammer drill, otherwise its works perfect, built to lasst these things, but parts are hard to come by in aystralia, anyone help me if you can please
lulu
Posted on Apr 28, 2011
How do you remove a stuck bit in the chuck of a TE 17 Hilti hammer drill?
Hilti TE56 SDS max stuck chisel remove - YouTube
? 7:10
https://www.youtube.com/watch?v=rmpvYuEvbIk
Jun 22, 2017 - Uploaded by Power tools fix
Hello, In this video you will see how to remove stuck chisel in Hilti demolition hammer. Same can be made for ...
Hilti SFC 22 A chuck removal and Makita chuck replacement - YouTube
? 7:12
https://www.youtube.com/watch?v=gkjBs0f0upg
Sep 15, 2017 - Uploaded by Power tools fix
Hello, In this video you will see how I removed Hilti SFC 22 A cordlessdrill chuck. I replaced genuine Hilti ...
Hilti TE76 stuck chisel remove and repair - YouTube
? 12:53
https://www.youtube.com/watch?v=v3ckL1lQ-2E&vl=cs
Nov 26, 2017 - Uploaded by Power tools fix
Hello, In this video you will see how to remove stuck chisel for Hilti Te76 demolition hammer. Same can be ...
How to disassemble and find problem in for Hilti TE 7 C rotary hammer ...
? 17:45
https://www.youtube.com/watch?v=4yY97AAHPO4 Feb 7, 2017 - Uploaded by Power tools fix
In this video you will see how to find problem in Hilti rotary hammer drill TE 7 C -~-~~-~~~-~~-~- Please ...
remove stuck bit in the chuck of TE 17 Hilti Google Search
Jun 12, 2018 | Hilti Drills
Hilti te 72 losing power when drilling
if the motor get hotter then normal this mean that the motor is coming to an end .
normally the armature or the coils of the motor starting to break down . but can be renewed , if the armature is broken that is the expensive part
Aug 01, 2017 | Hilti Drills
Hilti TE 17
I t will be poling or shorting out in the armature. Take it to a motor specialist but I think you will be up for either an armature or field windings.
Jul 27, 2013 | Drills
Need owners manual for hilti te 17
Owners manuals are no longer available. The TE17 has not been sold in over 30 years. Hilti no longer carries parts for the TE17. I can tell you just about anything you would want to know about the TE17s.
Lube: 30cc if the gear housing is still wet. 50cc if the housing has been washed out.
Older models had the "twist type" chuck. Meaning you would twist the chuck to insert the bit.
Newer versions had the "pull back" chuck.
If you have a black fill cap on top of the gear housing it meant that you did not have a safety slip clutch. If you had red cap then you did.
The armature rode on an oilite bushing which would tend to wear out and cause the armature to rub against the field.
If your 17 is still running then great run it until it quits. The only place to find parts are used ones on Ebay
Feb 24, 2011 | Drills
Need locations in europe and asia for spares outlet and price for armature assy for hilti TE 2s drill - ( due to short in windings and comutator) purchased on 1981 from saudi arabia -
Go to Hilti's website and choose your country. You can find locations and parts. The TE2s was not introduced until the early 2000's. In 1981 a drill that size would have been a TE12s. If that is your model parts are no longer available through Hilti.
Dec 25, 2010 | Hilti 284228 UH 650 Universal 1/2" Hammer...
Hilti TE 17. Hammer doesnt work. Rotary does.
Most likely the O-rings are worn - tool has no compression to move the hammers inside.
Less likely: the connecting rod for the piston is broken so piston isn't moving - or 2nd hammer is broken into pieces.
I would open it up & check the orings first
Jul 31, 2010 | Hilti Drills
Will the bits from the te-c3x fit my te-17
Yes. New bits will fit old Hilti drills. Old Hilti bits do not fit the new (last 15 years) Hilti drills.
Apr 07, 2010 | Hammer Set Of 6 Hilti Te-c3x Drill Bits...
Will a Hilti TE 17 to drill 1" holes in sandstone?
The TE 17 is at least 29 years old. It will do up to an inch. However there are no parts available for this tool. Also be carefull if it has a black fill cap on top of the gear housing then it does not have a safety clutch. If it has a red one then it does have a clutch.
Mar 05, 2010 | Hilti Drills
Hilti TE 17 Rotary Hammer repair switch fix The wirei loose how to reatach to motor?
Hope this helps.
Oct 29, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Need rear moter bushing for TE-17
Hilti has not carried parts for the TE17 for about 15 years. That tool was produced from the 60's up until the early 80's. The part you are looking for is an Oilite bushing that is held in the motor end cap. Even though the part is no longer available a good machine shop should be able to make you one.
Oct 25, 2009 | Drills
Drills Logo
60 people viewed this question
Top Hilti Drills Experts
John Trevino
Marvin
Marvin
Vincent G
Vincent G
Are you a Hilti Drill Expert? Answer questions, earn points and help others
