Question about Watches
Watch is blank need to open back an reset don't know how to reset
  • Not Me
    Not Me Nov 04, 2019
    Hi Jason Bergin, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What make and model please?
I dont know how to change it
Hi Mateo,
I suppose you don't know how to open the backside of your watch, to replace the battery.
If that is so, check the back side of your watch. At the edge of the centre cover, or just under it, there is at 1 place a little notch of a view millimeters. Juse a small screw driver or tweezers for instance to lift it up. If you don't succeed, the cover might be tight and sticky. So you need to put the back side of your watch on a hot and wet cloth. That might help to loosen the sticky edges.
Good luck ;)
Andre
Oct 20, 2012 | Watches
I need a manual to reset my watch
http://204.197.251.177/results.php#.UDtNTNaPVnQ
I don't know how they differ but there is a list of auriol watches here, although none match your specifics, but might be worth checking out.
Aug 27, 2012 | Swiss Army Wenger Wenger watch
Quess rist wacth back removel
I have used a very small screw driver to open most watch backs. The main issue with doing this is that if you are not very careful there is a big chance you can scratch it. There normally is a slight gap somewhere between the back and the case of the watch. That is normally where I put the very small screw driver and pry it open. If you watch has a special seal or has a very nice finish on it you may not want to try it. Also I have not tried to open a watch like that so I don't know for sure if it will work in this case.
Aug 26, 2012 | Guess Jewelry W13523L2 4 Watch for Women
Can the plastic band be opened? It won't fit over
you can ask for the instruction from the authorized retailer of your watch even that you don't have any proof that you don't purchase it to them. being the dealer of the watch brand it is their responsibility to assist all customers that need to know everything about the watch they selling.. now don't hesitate to ask them..
Jul 13, 2011 | Anne Klein 10-9119WTSV Watch
My battery is running dead . Can I have it replaced ?
Yes, the battery for this watch can be replaced. Timex estimates that the battery should last 2-3 years, but that assumes an "average" use of the Indiglo backlight. If you never use the backlight or audible alarms, your batteries would have lasted longer; heavy use of both would have run the battery down more quickly.
If you want to replace the watch battery yourself, you'll need a very fine philips or flathead screwdriver, the new battery, and a bit of patience. It would also be helpful to have a pair of tweezers, but that's not absolutely necessary. If you carefully look on the back of your watch, Timex usually lists the battery type so that you can buy a replacement battery without first opening the watch. If you can't figure out what the numbers mean, take it to a jewelry counter at Target or Walmart, and they should be able to help you decipher it. I don't know which battery this specific watch takes, but many Timex watches use a #1620 or #2016 3v battery. Look for a number like that on your watch back.
To open up the back of the watch, open the strap so that you have good access to the back. If you have a steel band, you might need to slip out one of the adjustment pins to separate the band into halves. Yes, you might be able to take the back off without this step, but it makes it a lot easier.
Place the watch face down onto a soft surface. I like to use a dark towel, so that if I drop one one of the tiny screws you'll be dealing with in a minute, they won't bounce and you can easily find them again.
Use your screwdriver to loose the back of the watch, one screw at a time. I find it very helpful to loosen a screw, then use the tweezers to pick it up out of the hole. These guys are tough to grab with your fingers! Put the screw in a safe place, then carefully remove the back of the watch. A little black neoprene gasket may be stuck to the back or be floating around--don't lose that!
You should be able to see where the battery is kept. On most Timex watches, there's a metal shield covering the watch and completing the power circuit. Using your screwdriver, gently pry the tabs of this shield away from the watch movement, one tab at a time. Try very hard not to snap off any of the little plastic anchors. On a Casio watch I recently serviced, I had to remove the movement from the watch to get at these little tabs; I don't remember ever having to do that with a Timex.
Once the shield is loose or removed, the battery should slide right out. Replace the battery, and gently snap down the metal shield. Turn the watch over to check whether it's working again. If it's not, you may have to push a little "reset" pin on the watch movement to clear the registries. The back of the metal shield usually has instructions on where that little pin is located. If the watch is already working, you won't need to do this.
Closing up the watch is the reverse of what you did to get it open. Make sure the neoprene gasket is back in place--that's what's keeping sweat and water out of the watch--and carefully set the cover back in place. Tighten the screws in an "X" pattern--i.e., top left, then bottom right, then bottom left, then top right. I get all the screws loosely screwed in before tightening them down in earnest. This watch has a plastic case, so you want to tighten the screws snugly, but not over-tighten them so that they strip out the screw hole.
May 10, 2011 | Timex Ironman 30 Lap 53952 Wrist Watch
After I changed a battery on R0614ZM TERNER watch, the display went berzerck and then blank altogether. Any ideas at all?
Some watches have a "reset" button or combination of buttons that must be pushed to clear all the electronic registries on the watch's little computer after you replace the battery. You might try taking off the watch back and seeing if your watch has this requirement. Even then, it's not always a perfect solution. Last week, I replaced the battery in a watch that had been dead for some time. The watch appeared to come alive again when I put the new battery in, but when I pushed the reset pin (on this movement, it was on the watch movement itself, next to the battery), the entire watch went dead. Nothing I did would wake it up. I removed the battery, waited 30 seconds, then re-inserted the battery. Problem solved; the watch powered up, and I was able to set the time and access all functions again.
On some digital watches from the 1980s, after replacing the batteries, you were supposed to push and hold all the external buttons for a few seconds to reset the watch. I don't think manufacturers still make watches that respond to this, but it is easier to try than taking off the back and re-installing the battery.
May 10, 2011 | Watches
My Timex Indeglo watch does not have any means of opening the watch so I can replace the battery. It kept perfect time when it ran, but now it does not run at all. Is it supposed to be a disposable watch...
  • If you don't already know what size battery you need, you can find this information on the back plate of your watch. Once you have your replacement battery, you will need to open the back of the watch to gain access to the battery compartment. Depending on the watch, the back plate will either screw off or be attached by a few small screws. If attached with screws, you will need a set of precision screwdrivers such as a jewelry or eyeglass kit.
    Inside the battery compartment, you will see the battery is held down by a clip. Carefully remove the clip and eject the battery. Insert the new battery and replace the clip. If the battery clamp indicates you should do so, quickly press the reset button twice. Then reattach the back of the watch. If the watch display remains off after replacing the battery, press all buttons at the same time to reset the display.
  • Mar 02, 2011 | Timex Indiglo Analog Watch
    Watch indicated "low battery" Jeweler replaced the battery but the watch did not respond and remains blank. The watch goes through 2 to 3 batteries per year and light remains on too long and cannot be...
    Hi
    Try resetting it - it worked for me. First, orient your watch face down (with the watch belt buckle opposite you), the new battery in and latched. Second, on the right side battery hold-down latch you will see a small metal circle (~1 mm diameter) with a black dot in the center. Take a small paper clip and touch this metal pad to the metal battery hold-down latch for about 1 second. This will reset the watch.
    Rotate the tiny donut that clips over the battery so it touches the brass spring that is next to the battery, replace the back plate. you can use a small tool to carefully lift the metal contact back up off the contact plate. Also make sure the back of the case is on tight as this also plays a role the electro mechanics of this watch.
    Let us know if you want to know something else accept the suggestion.
    Thanks for contacting fixya.com
    May 27, 2010 | Timex Ironman Data Link 5C291 Wrist Watch
    I have a Champion Sports Referee Watch. I need to
    Get to the alarm screen by pressing the mode button as many times as you need to. At the alarm screen, a short press on the lap-reset button toggles the chime on and off. Don't press and hold the lap-reset button: that toggles between alarm 1 and alarm 2.
    Mar 16, 2010 | Champion Watches
    When I press light buttopn in the middle the display goes blank
    This sounds like a simple battery replacement. Depending on how low the battery is usually pressing the light button and the display goes dim or blank is a good indicator of this. Takes a CR1616 battery and be careful of the spring inside and make sure the seal is in the correct position. You will need to touch the AC button and the back of the battery with a pair tweezers for a couple of seconds to reset the watch. Put the case back on and set the watch thru the functions.
    Dec 06, 2008 | Casio Baby-G BG169-2V Wrist Watch
    Watches Logo
    Top Watches Experts
    Janelle Schoonover
    Janelle Schoonover
    Marvin
    Marvin
    Are you a Watch Expert? Answer questions, earn points and help others
