SOURCE: Jenn Air wall oven-Broiler element comes on and will not turn off....
Boone, by the sound of your post it sounds like the power relay board could be bad. If you had a stuck or shorted keypad, you should be getting a different code. The F2 code means an overheated condition. If it's a double oven it could mean a secondary board failure. The way to go on this would be to ohm out the temp sensor first. Should read about 1100 ohms at room temp. Another way to check it is to swap the bake and broil wires on the power relay board. They will be marked BA and BR. Fire the oven up again and if the bake element comes on then you know that the broil relay is stuck or shorted. Without being there to do the tests, I believe that the problem lies in the power relay board. The part number for the board is 71003431. Priced around 116.00. Jenn-Air usually has a 5 year warranty on these parts. Hope this points you in the right direction. Catriver..post back
SOURCE: broiler element not working
It's either the switch that supplys power to the broiler element or it's the element itself (probably the element itself). I'd go after that first as it's not that expensive.
It's not a thermostat because if it was, the bake element wouldn't work either. The broiler element is not supposed to come on except when in the broil mode or cleaning mode.
SOURCE: Broiler element Whirpool Accubake electric oven not working
Hello
Welcome to Fixya
My name is Huum,
You need a new top element
http://www.pcappliancerepair.com/model-display.php
You can find the diagrams,schematics, and parts for your range at this site
Please remember to leave a rating before you leave
SOURCE: Frigidaire double oven has one element not working in each oven
sounds as if perhaps there has been a thermal overload(switch) tha has gone bad, refer to part number 119 on bothe the lower and upper oven for refernce , you should have continuity trough the switches.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/5995383394.pdf
SOURCE: broiler element comes on when "bake" is pressed
does the bake element come on at all?
if so, try the oven out. do a bake @ 350 allow it to pre-heat, and see if once the pre-heat is comlete, id the broil shuts off.
on many ovens at the beginning of the cycle during pre-heat both bake and broil elements are powered.
other than that it may be a control board, or a burnt and crossed wire in the harness.
