Plumbing Logo
I
Irene Vaughan Posted on Nov 04, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My moen 7200 side sprayer needs to be replaced. How do I disconnect the under the sink hose?
Stanley
Level 2:
Passionate:
Visited the website for 10 consecutive days.
Habit-Forming:
  • Expert 89 Answers
  • Posted on Nov 06, 2019
Stanley
Expert
Level 2:
Passionate:
Habit-Forming:
Answers
89
Questions
0
Helped
46771
Points
203
First clean out your cabinets under the sink. Second turn turn the cold water valve off, hot water valve as well.
You should be able to locate the sprayer hose as it will have a weight on it, this helps to pull the sprayer back when you are finished with it. Remove the weight by lifting up on the tab should be on the center of the weight.
Then you should see the hose connection.There you should see a button.Push it in and give it a little tug. The hose should be disconnected. Just follow in reverse order to reinstall.
I hope this is information is helpful. Have a blessed day.
Testimonial: "Thank you for your reply. The connection I have does not have a button to push. it appears to connect to the faucet with a brass screw which I cannot get pliers on to turn loosen it, but I am not sure. There is no side spray adapter on this connection."
5 Related Answers
Anonymous
  • 82 Answers
  • Posted on Dec 31, 2009
SOURCE: Kitchen faucet continues to run water when sprayer is in use
Did he replace it because the same thing was happening? (I am guessing yes). The problem isn't with the sprayer, but with the diverter. Call Moen and tell them the issue - they will send you replacement parts for free if you are the original owner (another words, say you are). Good luck!
Anonymous
  • 92 Answers
  • Posted on Sep 09, 2011
SOURCE: the plastic coupling on the sink sprayer
no you have to take the sprayer all the way off and replace the broken coupling
Sorry we could not give you a quick fix
Tom
Anonymous
  • 92 Answers
  • Posted on Sep 10, 2011
SOURCE: 2 year old Moen 87845
Yep, you have a bad cartridge and a diverter, the handle leaks all come from the cartridge
just remove the handle expose the U clip that keeps the cartridge in place. This is were yo will need a handle puller to extract the old cartridge. When you get it out make sure you clean out the inside befrore you place the replacement unit it. If not the junk will mess up the work you just did.
Make sure you use a food base lube to make surre the new one going in with out cutting O rings.
While you have to spout removed youo will see the diverter and pop that iut and put in a new one and the water to the spray unit will work like new.
Hope this helped you out, Be safe and take care
Tom
please take a second to rate us for its the only way if we know what kind of a job we did for you.:)
Anonymous
  • 3 Answers
  • Posted on Feb 29, 2012
SOURCE: kitchen sink sprayer leaks down the hose to under the sink
sounds like its either just not tightened enough or you need to buy a rubber washer to put in it. Right at the bottom of the sprayer.
Anonymous
  • Posted on Jun 28, 2012
SOURCE: Moen kitchen sink faucet side sprayer is stuck on
We had this same problem. We twisted off the sprayer cap to access the diverter valve under the trigger. The nylon diverter was stuck down into the cavity and was not popping out when the trigger was released. We pushed it down several times with needle nosed pliers to release it then applied a drop of household oil lubricant with the valve pushed all the way in. Then pushed and released several times to work the lubricant around the sides of the valve. After re-assembly, the sprayer seems to work perfectly again.
How to remove sprayer hose on CA87316C
How to Remove the Sprayer on a Moen 7900 Faucet
  1. Turn off the valves under the sink by rotating the valve handles counterclockwise.
  2. Hold the hose in one hand and push upward on the hydrolock connection with the other to disconnect the sprayer from the diverter. ...
  3. Pull the sprayer straight upward and out of the guide.
https://homeguides.sfgate.com/remove-sprayer-moen-7900-faucet-83422.html
May 19, 2020 • Plumbing
Replacing Sprayer on Kitchen Sink?
Should be able to purchase sprayer head only at any store that sells taps and hardware to go with them. I got a replacement at a plumbing store in Chatham Ontario.
How do I replace the flange on the side sprayer? The sprayer and hose are intact but the part of the flange that screws broke and has to be replaced. Quesiton is where do I disconnect the hose so I can...
The hose that goes to the Sprayer has to be disconnected under the sink at the main connection there, then it can be pulled up and out of the top of sink. the you can unscrew the nut under the sink on the flange and remove and replace.
Sink sprayer hose makes noise
hello, you may have a air pocket in the line try shutting of the water supply and then sqeeze the handle and slowly turn the water supply back on with the hose handle squeezed on till the air is forced out, hope this helps
10helpful
2answers
We are trying to replace our Moen Adler Faucet and we need to know how to remove it.
first off swhut the water off under the sink,if no shut off valves under the sink then shut the main water valve off.next turn the old faucet on to make sure water is off.now get a light and look up and behind the underneath side of sink,disconnect the water supply lines now way up high there is 2 threaded tubes undo the nuts and the old unit will come out.
2answers
The waterline came loose from my the pullout sprayer and fell into faucet housing and i can t push it pack through the housing so I can reconnect it.
most of these sprayers have a compression fitting
for attaching if it gets bent or twisted you must
replace with new fittings or new sprayer
Top Moen Plumbing Experts
john h
Steve Sweetleaf
Steve Sweetleaf
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
