Question about Maytag Ovens
My maytag digital oven 8114p734-60 12-99-00. After a power outage the display has everything lit up and the fan is running.
My maytag digital oven is the upper unit in a double wall oven. The number inside the door is 8114p734-60 12-99-00. After a power outage the display has everything lit up and the fan is running. I tried to hit cancel but that didn't work. I had to turn the breaker off to the oven. When I turn the breaker back on it still does the same thing. While the breaker was on I tested the lower oven which is not digital and it still works but I can use it because the fan on the top one runs constantly when the breaker is on and it has an electrical burning smell.
6ya staff
SOURCE:
Powerman
Charlie Popeck
  • 68 Answers
SOURCE: Built-in Electric Double Oven
The fan is controlled by a temperature sensitive switch. Apparently the switch is not shutting off when it should. It will have to be replaced. If you are not comfortable working around appliances, you will need to call a service technician. There is usually a set of maintenance instructions in the top of the oven. Check it out for any suggestions. Temperature switches can be purchased on line.
Posted on May 18, 2007
cheapiephp
  • 68 Answers
SOURCE: 4 Elements and Oven not working
If there was a power surge when the power went out or came back on, it could have fried the controller.
Posted on Jan 16, 2009
Anonymous
  • 706 Answers
SOURCE: lower electric wall oven won't heat up
It is highly likely that your heating element is open so I would ( with power removed) verify the integrity of the element by detaching it and making sure it is not elecltrically OPEN, It is nothing more than a big power resistor that when current is flowing,..gets hot but if it becomes open.. you will not have any curent flow thru it ( or heat generated from it). That would be the first place I would look.. It could also be the control that feeds it..
A few ideas to check..
Regards,
Rick
Posted on Feb 16, 2009
Rene J Solis
  • 1796 Answers
SOURCE: Need some detective work!
Hi!!
In order to get the an Owner's manual download you need to supply the E-NR FD numbers on the unit' s rating plate and go to this site https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM The rating plate looks like this
The location of the E-NR - FD numbers can be also found in the unit itself. Here are some usual locations, I know your appliance is a double wall oven, but I could not find a picture of one, so I got the closest thing available, an electric range w an electric oven. 1kbron_62.jpg
Now, if still you can not find the oven's rating plate, I suggest to take a couple of pictures of the oven, find a GAGGENAU dealer nearby, there is an email address and Ph. # on the link above. Or, click on the SERVICE tab, select Gaggenau Worldwide from the menu to the left of the picture, select the Gaggenau Dealer closer to you, contact them and send them the pictures, explain your situation and if they can provide the E-NR FD numbers to download and owners manual. Good luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Posted on Dec 12, 2010
espressonist
espressonist
  • 1711 Answers
SOURCE: After self cleaning process oven door would not
F3
or
F4
Shorted or open oven temperature sensor
(RTD) Check sensor harness and harness connection
between oven sensor and oven control. Replace oven temperature sensor (RTD) if
wiring is ok.
Posted on Dec 26, 2010
My ge oven stopped working after power surged code coming up on front panel: LCDBoard 'T_PP_Profile_V_3_35' Main relay V3.2, Aux Relay V3.2 EEPROM PARAMETER PAGE CRC 15 OEBC Initalization in progress
How to repair an oven: resetting the power - YouTube
? 3:13
https://www.youtube.com/watch?v=HenawxpSYow
Feb 14, 2011 - Uploaded by VideoJoeKnows
How to repair an oven: resetting the power might be the only thing you have to do....can you imagine? "You mean it ... My ovendoesn't work: what do I do now? ... How to Fix an F1 Error On a Kenmore or GE Range - Duration: 11:41. ... Oven Repair-Not heating after self clean-Kitchenaid,Whirlpool,Maytag ...
GE Oven quit working, after power outage - DoItYourself.com ...
www.doityourself.com/.../363632-ge-oven-quit-working-after-power-ou...
Oct 14, 2008 - Hi, our GE Glass Top Stove/Oven stopped working after a power outage ... My guess: the circuit board on the oven (behind the digital display) ...
Dec 29, 2015 | GE Ovens
Why won't the clock stay lit? Shows the correct time, but only stays on for a few seconds.
Some clocks work that way. I guess they're just saving power.
Hope this helps.
Feb 24, 2015 | Ovens
Gaggenau EB944-110 Pyrolytic oven stuck in some kind of mode after power outage. Oven worked perfectly but there was a mains cut. After restoring power it appears to be stuck in some kind of strange...
Yes this could be the problem. If you can't set the timer to manual mode the oven will not work. Turn the oven to on so that when power goes to it you will see the oven indicator light come on. Play with the timer buttons until the oven indicator light comes on. If it won't work you probably need a new timer.
Feb 11, 2011 | Ovens
What does pf on digital display mean? Oven will not work
PF means power failure.
This has caused a power outage to the oven.
This error can be removed by resetting the clock.
Hope this helps.
Thanks for using Fixya.
Dec 07, 2009 | Whirlpool Ovens
Cannot get display clear on kenmore oven
Unplug the cord behind the oven. You'll need to pull out the oven a bit. Not too far as the flexable gas line is there also. Wait 10 min and replug the oven. This will reset the curcuit board after the power surge.
Apr 29, 2009 | Ovens
Error code E3 - F3 on Whirlpool oven, RBS275PDB12
Error E3-F3 says that the Oven temperature is too high(Clean mode).You might have to replace the Oven Temperature Sensor(RTD).
Apr 19, 2009 | Ovens
F7 code on maytag cwb3100aab 24" wall oven.
Hi, The Function key is shorted or stuck.
Replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Apr 11, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
Microwave
Hi my GE Advantium oven is displaying an error message and beeping. The Error is F3. Could you please help me with this.
Nov 02, 2008 | GE ZSC2001FSS Advantium Electric Single...
Power outage Blodgett Conveyor Oven
On the back of the motors there are safty overload reset's, these are small red push in buttons. Also there are fuses for each motor inside the control panels assembly.
Jun 02, 2008 | Blodgett Ovens
Display 11
your control must be fried...dacor fault codes are f0 to F8 the display must be faulty..
Aug 25, 2007 | Dacor ECD230 Epicure Electric Double Oven
Ovens Logo
69 people viewed this question
Top Maytag Ovens Experts
Marvin
Marvin
Paul Carew
Are you a Maytag Oven Expert? Answer questions, earn points and help others
