You should be able to download the manual for free yourself. If you are unable to do so, ask a trusted friend or relative to help you.
https://www.manualslib.com/manual/118646/Panasonic-Rn-202.html
SOURCE: Casio Model #PCR-202 cash register
That model is so far out of date it's near impossible to find a manual. You can find some solutions to FAQ here:
http://www.casio.com/support/techsupport/spd/pcr202.html
Other manuals (may be able to find a similar model) here:
http://www.casio4business.com/sa/support/downloads/downloads_manuals.html
SOURCE: i need the instructions manual
put in 2 AAA batts and insert a tape, then push record to record, and expirament!
VCVA
set it to VCVA on the left side and push record, will only record when detects noise
SOURCE: I need to consult a
unfortunately,
the user manual for your Micro-cassette recorder
is not available anywhere online.
The manufacturers of this product did not make it available. I went
further searching and couldn't find any.
I would suggest you
contact the manufacturer of your micro cassette recorder via phone or e-mail and
request for the user manual from them. They might give it to you or direct
you to a dealer where you can get the manual.
This is the best you can do to get the user manual you are requesting for.
Lastly, to buy another similar device, when you get to the manufacturer's website, you will find other similar devices or upgraded ones.
Good luck.
SOURCE: looking for onwers manual for
http://www.usersmanualguide.com/panasonic/microcassette_recorder/rn-305
You can download the User Guide from that webpage.
If this solves your stated problem, please come back and rate our solution. Thank you.
Most major manufacturers supply manuals
online so if you were to log on to the manufacturer's web site, you
may be pleasantly surprised as usually, if available, one is able to
download, by model number, Customer
Instruction Manuals, Dealer
Network for spare part supplies and
Driver
downloads
(if applicable)
as required.
The information is normally free of
charge.
I hope this helps.
