I have SL dv280 5 dvd /cd discs Changer model 2002 wanna replace with SL dv290 5 dvd/cd changer model 2003 mp3 it will work with rest 3 pieces only with changed of changer
Hi Asad, I'm sorry to tell you that SL dv280 and SL dv290 are not compatible, they have the same connector, but different signal configuration
Do not try to test, because you could damage the devices
To work well, you must replace all of the devices with those of line 290
Regards Franco Dosil
Hola Asad, lamento decirte que no son compatibles el SL dv280 y el SL dv290, tienen el mismo conector, pero distinta configuracion de se?ales
No intentes probar, porque podrias perjudicar los aparatos
Para que funcione bien, deberas reemplazar la totalidad delos aparatos por los de la linea 290
Saludos Franco Dosil
http://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Technics-SLDV-280-GN-Service-Manual.pdf
https://elektrotanya.com/technics_sl-dv290_sm_html.rar/download.html
SOURCE: Technics 5 cd changer Model SL PC11 will pick up
This is a problem with the laser assembly which requires service. The laser assembly needs to be replaced as a whole. It is not easy to replace them, but someone with patience, and a knack for mechanical things can do it.
SOURCE: Technics dv290 system
i once had a panasonic dvd player which displayed the same code H02 and used the same drive mechanism as your player. this turned out to be a worn spindle motor and once replaced, all worked fine. you may well have the same fault. hope this helps?
SOURCE: missing remote for Technicis Model SL-MC59 Cd changer
You will need to go online to Technics and contact customer support and the technical department to see if they can help.
