Its All In One PC, should don't have Batteray on It
AIO PCs seem to love to die,
the PC
so PC is silent, means lost of power, check AC cable, make sure to use wall jack AC not a power strip.
AIO are not easy to fix, most parts in side are non standard
so that makes them a pain.
why not get shop to fix it.?
did you hold the power button in for 5 full seconds as page 2 in your service manual directs.?
repeat that 2 times, 1st to end buggy sleep drivers, 2nd to hard power it on,
if that fails the , PSU bad top cause. (silent PC)
SOURCE: I have a omni 1000
The UPS is either off, has a dead battery or is dead. Does the UPS power anything at the surge only outlets? If it doesn't, it's off or dead. Turn it on and check again.
The Omni 100 VS does not have a user-replaceable battery or other parts. If the battery or UPS is dead, replace it.
I hope this helps.
(when the UPS is off but connected to power, the battery should charge.)
