Question about Technics Audio Players & Recorders
How do I connect Technics SL PD7 to Technics SA-DX750?
    Top Expert:
  • Technics Master
  • 10,535 Answers
Hi Anonymous, you have two ways to connect the Technics SL PD7 CD player to the Technics SA-DX750
The first is through a fiber optic cable, from the Digital Optical output of the SL-PD7, to Optical Input 1 or Optical Input 2
The other alternative is to use a 2 RCA to 2 RCA cable and connect them between the L and R outputs of the SL-PD7 to the CD L and R inputs on the SA-DX750
I hope you can interconnect the equipment
Regards Franco Dosil
Hola Anonimo, tienes dos maneras de conectar el reproductor de CD Technics SL PD7 al Technics SA-DX750
La primera es a traves de un cable de fibra optica, desde la salida Digital Optica del SL-PD7, hasta la Entrada Optica 1 ? Entrada Optica 2
La otra alternativa es usar un cable de 2 RCA a 2 RCA y conectarlos entre las salidas L y R del SL-PD7 a las entradas L y R de CD en el SA-DX750
Espero puedas interconectar los equipos
Saludos Franco Dosil
https://www.manualslib.com/manual/169257/Technics-Sa-Dx750.html
http://www.usersmanualguide.com/panasonic/compact_disc_changer/sl-pd7
Posted on Nov 04, 2019
6ya staff
SOURCE:
VOTIT
LORETO LACARON
  • 2071 Answers
SOURCE: How do I conect my ipod to the Technics AV control
You just connect it in the auxilliary input then switch your reciever to auxilliary so you can the sound of your ipod. First buy a wire connector from ipod to reciever.
Hope it may helps;
Regards:
VOTIT
Posted on Jun 17, 2009
ABRsvcs
  • 4234 Answers
SOURCE: OVERLOAD
First of all the KEF is a powered sub which means that it wants a line level signal NOT a speaker level. Send the signal from a tape output or pre-amp output to the sub input. The overload is because the impedence load for the speaker output is too low and looks like a short to the amp. Continued attempts to connect the system as described will result in damage to the output section of the amp.
Please let me know if you need more info.
Dan
Posted on Feb 03, 2010
Grubhead
Grubhead
  • 5699 Answers
SOURCE: on switching my technics sa-dx750 it says switching off overload
The question is what is causing the overload? The power supply or the output devices on the heat sink?
If you have accidently shorted a speaker wire, then the answer will be output devices, otherwise it could be anything in the power section. You may find a burnt or damged device with either of the causes.
Posted on Mar 09, 2010
hmerchant110
AliTech110
  • 7191 Answers
SOURCE: would like to see the manual on the technics
You can download the complete instruction manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
Posted on May 10, 2010
ripleymojica
Mando Mojica
  • 643 Answers
SOURCE: Problem with the Technics SA-DX750
bad powersupply.
Posted on Mar 21, 2011
I need a replacement romote controller for my technics sa dx750 receiver
Newremotecontrol.com has a substitute remote with the same features as the original. Part# EUR7702KK0 for around $29.99. The original remote is obsolete.
Apr 09, 2012 | Technics SA-DX750 Receiver
SA-DX750 error F70
I have a technics sa dx 750 receiver that cut...
Dec 21, 2010 | Technics SA-DX750 Receiver
Technics sa-gx670 reciever sound drop
it could be that your amp chips are gettin hot
Jul 22, 2010 | Technics SA-DX750 Receiver
Would like to see the manual on the technics sa-dx750 5.1 channel receiver
May 10, 2010 | Technics SA-DX750 Receiver
On switching my technics sa-dx750 it says switching off overload
Mar 08, 2010 | Technics SA-DX750 Receiver
OVERLOAD
Dan
Feb 03, 2010 | Technics SA-DX750 Receiver
How do I conect my ipod to the Technics AV control receiver SA-DX750?
Hope it may helps;
Regards:
VOTIT
Jun 17, 2009 | Technics SA-DX750 Receiver
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
