Setting time for QQG142G clock - Audio Players & Recorders
    Top Expert:
  • Audio Player... Master
  • 55,370 Answers
Google (brand)(QQG142G)(manual) without parens for instructions.
Posted on Nov 04, 2019
6ya staff
SOURCE:
How do I set the time on a RCA USB Charging Clock Radio RC142?
Setting clock manually
1. Press and hold Set Time to enter the clock setting mode.
2. Press HOUR+ and MINUTE+ to adjust the time.
• Press and hold to adjust the time value quickly.
• The digits on the display ? ash in clock setting mode.
• The clock is in 12 hour format. The AM or PM indicator will illuminate to indicate the current time setting.
3. Press Set Time again to save the time setting
RCA RC142 User Manual General Controls
Mar 18, 2016 | RCA RC142 AM/FM USB Charging Clock Radio
Tip
Procedure For Setting Time Zones For Emerson Clock Radios
Setting The Time, The First Time
IMPORTANT: The first time you connect your new SmartSet® clock radio to
the AC outlet the internal computer will automatically set the time correctly for
the Eastern Time Zone, which is the initial default setting. The display will
scan for a few seconds and then show the correct Day and Time in the Eastern
zone. If you live in the Eastern Time zone, there’s nothing else to do. Your
clock is set correctly and running.
If you do not live in the Eastern Time zone you must change the default zone
display to your own zone. You only do this one time and the SmartSet® will remember
the new default zone setting and will always return to that setting after a power
interruption.
There are 7 time zones programmed into your SmartSet® clock radio as follows:
ZONE 1 — Atlantic Time
ZONE 2 — Eastern Time (Default Setting)
ZONE 3 — Central Time
ZONE 4 — Mountain Time
ZONE 5 — Pacific Time
ZONE 6 — Yukon Time
ZONE 7 — Hawaiian Time
To change the default time zone display, depress the Time Zone button.
The number “02” will appear on the display
indicating that the default zone is ZONE 2,
Eastern Time
on Jun 12, 2009 | Emerson Smartset Clock Radio
How do u set clock on deh p3000 pioneer
This was copied from the Pioneer support site:
Clock adjustment is performed in the "Initial Settings" menu. Please follow the instructions below to access time setting.
Press & Hold [OFF]
Pres & Hold [Muti-Control] until "Clock Set" Appears
Turn [Muti-Control] to choose setting
Press [Muti-Control] to enter setting
Time Setting:
Press [Muti-Control] to select time setting mode
Press [Muti-Control] to select time segment. Each press will select one segment of clock
Turn [Muti-Control], or click up/down to adjust time segments
Available functions:
Clock Set, Warn Tone, AUX 1, AUX 2, SW Control, Ever Scroll, BT Audio*, Pin Code Input*, BT Ver Info*
*Available only when bluetooth adaptor is connected
Feb 24, 2010 | Pioneer DEH-P3000 CD Player
7:15 p.m., 10/6/09-I don't know how to set up the time & date on the machine. I need clear, step-by-step instructions. Help! AT&T digital answering machine model 1738. THANK YOU!! Barbara S.
To set the clock. You must set the clock once so that the system announces the correct day and time with your messages. After this, if you subscribe to Caller ID, the system will automatically reset the clock each time new call information is received.
Press PLAY/STOP to exit at any time while
setting the clock.
1 Press and hold CLOCK until the Message Window displays C, and the default day is announced.
2 To change the day setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct day is announced.
3 Press and release CLOCK. The current hour setting is announced.
4 To change the hour setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct hour is announced.
5 Press and release CLOCK. The current minutes setting is announced.
6 To change the minutes setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct minutes setting is announced.
7 Press and release CLOCK. The current year is announced.
8 To change the year setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct year is announced.
9 Press and release CLOCK. The new day, time, and year are announced.
To check the clock, press and release CLOCK.
If you need futher instructions for your answering machine you can download a copy from:
http://phone.manualsonline.com/manuals/mfg/att/1738.html
Please rate this solution. Thanks..
Oct 07, 2009 | AT&T Lands Phones
Need to reset time ,day and date
Setting the Clock
You’ll need to set the clock so that it can
announce the day and time that each
message is received. Press Play/stop to exit
Setting the Clock at any time.
1 Press and hold Clock until the
2 To change the day setting, hold down memo/repeat
or ANNC/Skip until the
correct day is announced. Then
release the button.
3 Press and release Clock. The current
4 To change the hour setting, hold down memo/repeat
correct hour is announced. Then
release the button.
5 Press and release Clock. The current
6 To change the minutes setting, hold
down memo/repeat or ANNC/skip until the
Then release the button.
7 Press and release C. The new day
and time are announced.
Clock.
NOTE: In the event of a power failure,
see the instructions on the bottom of the
unit to reset the clock.
Record a memo /
Repeat all or part of a message
I hope this helps! here is the URL to the information provided
http://telephones.att.com/docMgt/public/art/162/1717_manual.pdf
Feb 09, 2009 | AT&T 1717 Digital Answering Machine
Model 1739 answering machine
Set the clock
You must set the clock so that the system announces the correct day and time with any incoming messages. After this, if you subscribe to the caller ID service, the system will update the clock eac h time new call information is received. Press PLAY/STOP to exit at anytime while setting the clock.
1. Press and hold CLOCK until the message window displays C and the default day is announced.
2. To change the day setting, press
3. Press CLOCK. The current hour setting is announced. The correct day setting is saved.
4. To change the hour setting, press
5. Press CLOCK. The current minute setting is announced. The correct hour setting is saved.
6. To change the minute setting, press
MEMO/REPEAT or ANNC/SKIP until the correct minute setting is announced.
7. Press CLOCK. The cu rrent year is announced. The correct minute setting is saved.
8. To change the year setting, press
MEMO/REPEAT or ANNC/SKIP until the corr ect year is announced.
9. Press and release CLOCK. The new day, time and year are announced. The correct year setting is saved.
To check the clock, press CLOCK.
Jan 08, 2009 | AT&T 1717 Digital Answering Machine
Clock setting on Pioneer DEH-P77DH in dash cd player
Setting the Time
This is the mode for setting the time on the unit’s clock display. (Refer to page 51 for
details concerning the clock display.)
As soon as you switch to “Minute”, the seconds start counting from 00.
1. Press the FUNCTION button and select the Time setting mode in the InitialSetting Menu
always select “OFF”.
2. Select “Hour” or “Minute”
with the < / > buttons.
3. Set as desired with the ^ / v
buttons.
Jan 04, 2009 | Pioneer DEH-P77DH CD Player
How do I set the time on my Pioneer RT500?
Hi!
Please follow the instructions given below... =)
Setting the clock
The clock is set to the correct time automatically, but it
can also be set manually. The clock can be set for
daylight saving time and time zone.
Preparation:
• Turn ON the TV and set it to the video input mode.
• Select “CLOCK” from “SYSTEM SETUP”. For the
procedure, see steps 1 to 3 in “Using the SETUP
MENU”
1 Press SETUP while the DVD and video tape is
stopped.
The SETUP MENU screen will appear.
TIMER REC SET
SYSTEM SETUP
AV SETUP
REC SETUP
CH SETUP
OTHER
SETUP MENU
ENTER/
SELECT ENTER RETURN BACK SETUP END
SELECT
2 Press  or  to select the desired menu and
press ENTER.
The submenu screen of the selected menu will appear.
TIMER REC SET
SYSTEM SETUP
AV SETUP
REC SETUP
CH SETUP
OTHER
LANGUAGE
PARENTAL
CLOCK
DISC SETUP
OTHER
SETUP MENU
3 Press  or  to select the desired submenu and
press ENTER.
The screen for the selected submenu will appear.
CLOCK (manually)
You can manually set the date, year and present time
with the remote control.
Ex.: Setting the clock to “10:20AM” October, 30th, 2004.
1 Select “CLOCK” and press ENTER.
01/01/04 12:00AM
2 Select the desired items using  or  (month,
date, year, hour, minute and AM/PM) then press
ENTER.
3 Press  or  to set the value of the selected
item.
• For the minutes, press  or  once to set the time
minute by minute, or hold down either of buttons
for several seconds to set the time in 10-minute
intervals.
10/30/04 10:200AM
4 Repeat steps 2 and 3 to set the date, year and
present time, and press ENTER. The SETUP MENU
will close.
This completes clock time setting.
AUTO CLOCK
You can automatically set the clock by turning “ON” the
AUTO CLOCK function.
When you want to set the auto clock function to “OFF”,
select “AUTO CLOCK”, press ENTER and select “OFF”
from the list.
Auto clock setting
Preparation:
You must connect the antenna or cable before connecting
the AC cord to the power source.
Wait 30 minutes with the power turned off, after the
antenna or cable is connected, for the auto clock
feature to activate.
After the clock is set automatically, you may have to set
the time zone and daylight saving time. (See page 26.)
Press STANDBY/ON to turn on the DVD/VCR after the
auto clock operation completed.
• When shipped from the factory, the “AUTO CLOCK”
option is set to “ON” position.
• If you turn the DVD/VCR on during auto clock
setting, the clock is not set.
• After a power failure or disconnection of the power
plug, the clock setting will be lost. In this case, wait
30 minutes before turning the DVD/VCR on.
• With cable box connection, if the auto clock setting
is unsuccessful, select the PBS channel carrying
the XDS information, then turn the DVD/VCR off.
After 30 minutes, turn the DVD/VCR on.
• If the clock is not set automatically, set the clock
manually.
STANDARD TIME (Time zone)
In the rare event that you live within the broadcast range
of two stations in two different time zones, the DVD/VCR
may recognize the wrong station for the auto clock set.
To correct the situation:
Select “STANDARD TIME” and select the time zone from
the list below.
Selectable time zones and correction times
ATLANTIC: GMT – 4 hours
(GMT: Greenwich Mean Time)
EASTERN: GMT – 5 hours
CENTRAL: GMT – 6 hours
MOUNTAIN: GMT – 7 hours
PACIFIC: GMT – 8 hours
ALASKA: GMT – 9 hours
HAWAII: GMT – 10 hours
AUTOMATIC: AUTO SET
Note
• When shipped from the factory, the “TIME ZONE” is
set to “AUTOMATIC”.
• After making the auto clock setting, in some cases
the clock may display another time zone. You can
correct the clock by selecting your time zone
setting above.
• When the clock is not set or you set the clock
manually, the time zone setting is not available.
DAYLIGHT SAVING TIME
You can set the clock to daylight saving time automatically
or manually.
To select daylight saving time, select “DAYLIGHT
SAVING TIME” and select “ON”, while to cancel the
daylight saving time, select “OFF”.
ON: For manual setting (forward 1 hour)
OFF: For manual setting (back 1 hour)
AUTOMATIC: For automatic setting (read XDS in
the signal)
Note
• When you want to set daylight saving time, on the
first Sunday in April you set it to “ON”, and on the
last Sunday in October you set it to “OFF”.
• When shipped from the factory, the “DAYLIGHT
SAVING TIME” option is set to “AUTOMATIC”.
• When the clock is not set, the daylight saving time
• When there is no daylight saving time in your area,
Jan 03, 2009 | Pioneer DVR-RT500 DVD Recorder/VCR
Need to change the date and time
message is received. Press "Play/Stop" to exit
1 Press and hold "Clock" until the
"Memo/Repeat" or "ANNC/SKIP" until the
release the button.
3 Press and release "Clock". The current
"Memo/Repeat"or "ANNC/SKIP" until the
release the button.
5 Press and release "CLOCK". The current
down "Memo/Repeat" or "ANNC/SKIP" until the
7 Press and release "CLOCK". The new day
"Clock".
Nov 26, 2008 | AT&T 1717 Digital Answering Machine
Clock setting on alpine iva-w200
Copied from Alpine-usa.com support page:
Setting item: CLOCK ADJUST
Further setting items : HOUR / MINUTE / TIME ADJUST
Setting content: 1-12 / 0-59 / RESET
The clock-adjusting mode is canceled when the power is turned off,
when [RETURN] or [CONTROL] is touched.
Setting item: DAYLIGHT SAVING TIME
Setting content: OFF / ON
Setting the Time
HOUR: Adjust the hour.
MINUTE: Adjust the minute.
RESET: If the clock shows less than 30 minutes past, the
minute will be “: 0”; more than 30, the hour
advances.
Setting Daylight Saving Time
ON: Place the Summer Time mode ON. The time advances by
one hour.
OFF: Return to the ordinary time.
Aug 19, 2008 | Alpine IVA-W200 2-DIN DVD/CD/MP3/WMA...
Ekse
 Grubhead
Grubhead
